ilovef-4 wrote: | Glad to see you go the info you needed there Air Master. Great job on the cockpit and the mating of the bride and groom. Update on my F-4E, rescribed panel lines on th fuselage halfs and ordered intakes, wheels and int/ext detail kits. Also cleaned up some ugly pieces on the wings and slabs. I will post pics as soon as I get batteries to take pics. Still looking for info about the aircraft that I plan on doing. I was wondering how you made the heads on the M-9 missiles. Charlie |
Ahhhhh, Young padwan, making clear seeker heads for AIM-9 Sidewinders is easy! 1. Take the clear sprue that your models canopy parts came on and cut off some of the rounded plastic that the held the parts to the sprue tree, cut off about 1/16" of an inch from the sprue. Use a razor saw blade to cut them. You may want cut more than you need just incase the carpet monster gets hungry he will have snack. Now file down the flat ends and set them aside. 2. Get your AIM-9's out and cut 1/16th" off the tip and file tip flat. 3. Take some super glue (CA) and glue the clear rounded pieces to the missile tips and secure it by brushing on some more Super Glue (CA) at the tip and let it cure. 4. After CA has cured take 400 grit sand paper and sand sides flush to the missile shaft and the tip sanded round, 5. Next take a 4 grit nail polishing stick and polish only the tips untill they're clear as glass, start with the Buff grit and work down to the Polish grit. 6. Paint your missile accordingly but dont paint the top tip on the missile. Mask off the tip before painting. 7. Viola, Realistic looking missile seeker heads on your AIM-9's. Before adding stripes brush on some Future or gloss coat the missile. I used decals for missile stripes and they will adhere better to a glossy smooth surface, and seal decals with gloss coat after and mask tips again before spraying on a clear dull coat. Let me remind you that I have been doing this for years and perfected my technique so, if you make a mistake keep working at it until you get it right. Patience and persistace will pay off. This is the way I do it and hope this helps you toward getting them looking like the real thing. |
