DML Sdkfz 164 Nashorn COMPLETE pics p.14 03-13-10
    July 2004
Posted by wbill76 on Saturday, February 27, 2010 5:07 PM
The old saying that the devil's in the details really holds true on this particular build. Today's efforts continued to focus on the remaining details and the time it took to address them turned out to be more than I had anticipated. The goal was to get to the weathering stages this weekend but that's not likely to happen given the cure times needed for the Future and decal stages.
Despite that, a lot did get done today. I assembled all of the road wheels and installed them to both sides of the hull, checking for a level fit, and let that set up. Then the lower hull was pre-weathered by stippling some enamel Burnt Umber with a round 0 sable brush to simulate random scratches and dings due to rocks, dirt, etc. being kicked up by the tracks. I also painted and detailed the vehicle exhausts on either side before installing the return rollers in order to have some room to work with. They were base coated with MM Non-buffing Metalizer Gunmetal and then given a light wash of Rust to create their look.
The jack block was painted and detailed by hand with the wood portions getting a base coat of a tan "wood" mixture I created a long time ago followed by a wash of thinned MM enamel Leather. Both Black and Burnt Umber artist pastels were added for some variation. I also installed the vehicle's standard antenna mount but modified it by removing the stub post with sprue cutters and drilling out the base with a #72 finger drill to allow for a brass 2m antenna to be installed later. I also detailed the release catch cable for the travel lock with non-buffing metalizer Gunmetal and lightly dry brushed the pulley wheel with Steel.
The rear hull also got some attention with the two spare road wheels added along with their mounts. The gun cleaning rods were detailed the same as the jack block with the threaded end caps detailed using MM enamel Steel. The rear blackout light was painted with Flat Sea Blue as well.
The remaining details for the fighting compartment that I'd left off for easier painting/access were added at this point as well. The instructions tell you to install 3 of the swinging MG mounts but I decided to leave the one they wanted at the rear off. I couldn't find any photographic references that supported a 3rd mount and the surviving vehicle at Aberdeen only has the two on the sides so that's what I went with. The bases are PE and I hadn't realized just how large they were otherwise I would've added them earlier in the build since it was a very tight fit to get them installed properly above the ammo bins due to the height and angle of the side walls. I added the swivel mounts and glued them in place with CA gel.
The two side wall periscopes were also detailed and installed. Since these were Bakelite and held in place with small metal frames, I painted them first with MM enamel Italian Dark Brown and then detailed the frames using the same DY mix as the vehicle base coat. For the plexiglass faces, I used enamel Steel followed by Tamiya acrylic Clear Smoke.
Last but not least, the commander's rabbit-ears scope was added. This is a tricky multi-part assembly that has two parts for the base and another 3 parts for the scope itself, so it had to be assembled in stages to allow the delicate parts to set up properly. The scope was base coated with non-buffing metalizer Gunmetal and lightly dry brushed with Steel and then given a very light black artist pastel treatment. The lens faces were treated the same as the periscopes to complete its look.
I assembled the multi-part jack and painted it a slightly different shade of DY in order to provide some visual variance relative to the rest of the vehicle. Instead of a 50-50 mix of Panzer DY/Light Gray, I used an 80/20 mix.
The hull front also received some details in the form of the spare track run. I used the kit-supplied Magic links for this and selected 14 from the baggie. Each one needed some slight cleanup to remove a small sprue nub on the guide horn and some sanding to remove two small raised ejector marks on the exposed face of each link. The links were glued together with regular glue, base coated with non-buffing metalizer Gunmetal, dry brushed with Steel, and then given a wash of Rust. Once the wash had dried, I dry brushed MM enamel Burnt Umber to round out the look and installed the run in place in the holder.
The final task of the day involved the tracks. I pre-weathered the sprockets and idlers with the same stippling approach used on the lower hull and also added some dry brushed Steel for the sprocket teeth and the contact surfaces on the idler.  I added the base of the idler to the actual idler wheels and did a test fit with the MK tracks to see how many links and what position the idler could support. The track runs were extended to the recommended 104 links and the idler is capable of properly tensioning them with anywhere from no sag at all to full sag (if there is such a thing!), so I was happy with that outcome.
Tomorrow the tracks will get painted and installed and then the Future coats will be added along with the markings. At least that's the plan!
    August 2008
Posted by Pvt Mutt on Saturday, February 27, 2010 5:43 PM
Bill you're breathing some life in her now bud.Toast
Tony LeeSmile
Shoot Low Boys They're Ridin Ponys
    December 2008
Posted by model maniac 96 on Saturday, February 27, 2010 8:50 PM
Very nice!
"Veni, Vidi, Vici" Julius Caesar: I came, I saw, I conquered.
    January 2012
Posted by I make stuff on Sunday, February 28, 2010 1:43 AM
I really like that camo, Bill, interesting scheme and it's well executed, as usual.
Looking ofrward to seeing the finishing touches on this one.
Bill
    January 2008
Posted by Bodge on Sunday, February 28, 2010 4:47 AM
Yet another masterpiece in the making BillBow Down
Congrats on your Mag article, front cover, WOW i want some of that. im jealous.Balloons
I havnt seen it in the flesh yet as it seems to take forever to get in our shops over here in old Blighty.
    July 2006
Posted by redleg12 on Sunday, February 28, 2010 6:59 AM
Bill - Another busy weekend....very nice details....coming along nicely
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    January 2009
Posted by Schnobs on Sunday, February 28, 2010 9:49 AM
Paint is looking great Bill!
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance. That principle is contempt prior to investigation." Herbert Spencer
    July 2004
Posted by wbill76 on Sunday, February 28, 2010 10:46 AM
Tony, thought you might like this point in the build! As with all open-tops, it's the details that really make it come alive IMHO.
Wayne, MM96, Bill, Mike, and Ed, thanks for the comments!
BeerAndy, thanks for the comments and for the congrats on the mag cover! Nothing to be jealous of IMHO though as your work is cover-worthy in its own right. Wink Hope you get your issue soon, postal services can be notoriously bad once you cross the pond...case in point, I just received a 2009 Christmas card from Poland in the mail yesterday! Propeller
    January 2008
Posted by Bodge on Sunday, February 28, 2010 12:14 PM
Thats crazy BillSnail
    July 2004
Posted by wbill76 on Monday, March 1, 2010 1:47 PM
No kidding Andy...I sent a note to the sender and he was absolutely stunned! He just thought I'd been ignoring him this whole time. Propeller
    May 2006
Posted by panzer88 on Monday, March 1, 2010 2:21 PM
Looking REAL nice, REAL nice indeed.Big Smile
    August 2009
Posted by M1Carbine on Monday, March 1, 2010 3:08 PM
Looking SWEET! Bill
Bob
    July 2004
Posted by wbill76 on Monday, March 1, 2010 10:29 PM
Thanks panzer88 and Bob, appreciate the comments!
Wayne, I hear you about the good ol' USPS...still I have to say that for me at least being in El Paso where there's a Regional Sort Facility things usually get here reasonably fast but that Christmas card really took the cake this time around! Big Smile
    July 2006
Posted by bufflehead on Monday, March 1, 2010 10:35 PM
Seems I missed an update to two!  Looking fantastic with paint on her Bill!  And I can see the great interior you worked on!!  YAY!
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
    July 2004
Posted by wbill76 on Tuesday, March 2, 2010 9:12 AM
Thanks Ernest, glad you've caught up on this one, appreciate the comments. Beer
    May 2005
Posted by hughes2682 on Tuesday, March 2, 2010 10:18 AM
Bill,
Congratulations on the mag cover.  I got the issue the other day.  Gotta love those Stugs.  Solid work on the Nashorn by the way.Yes  I sent a T-34 rear deck part to Zero Enna in Peru.  It got there in seven days time.  He sent me a message when it got there. I was amazed!!!Surprise
Cheers
Dave
http://img.photobucket.com/albums/v317/Aaronw/Groupbuilds/ClassicAviationGB2010bomb.jpg
With enough thrust, pigs fly just fine.
    July 2004
Posted by wbill76 on Tuesday, March 2, 2010 1:09 PM
Thanks Dave! I truly think the problem is with the Polish mail system and not the US system...I've ordered things from Poland before for example and they've taken literally weeks or months to arrive.
    July 2004
Posted by wbill76 on Tuesday, March 2, 2010 8:26 PM
I managed to get quite a bit of work done on Sunday but held off posting until I had the markings on and everything was set for the weathering process. The MK track runs were given an airbrushed primer coat of MM enamel Flat Black to protect the bare plastic from the lacquer-based base coat of Non-buffing Metalizer Gunmetal. The tracks were then dry brushed with MM enamel Steel and given an overall wash of enamel Raw Umber to round out their look.
The tracks were installed to both sides along with the sprockets and idlers. The vehicle was then set off to the side to allow everything to set up nice and solid.
The entire vehicle was sealed with a coat of Future applied by air brush. Ordinarily I would allow this to dry for about an hour or so before moving on to the decals but I ran out of time on Sunday so the coat got to sit longer than normal as a result. The decals were applied for the Italy 1944 sPzJgAbt 525 vehicle but instead of using the finishing guide for #131, I used the guide for #112 which is also included. These vehicles belonged to the same unit and would have the same insignia/markings but for some reason the finishing guide for #131 doesn't follow the same standards as that provided for #112 in terms of the numbers placement and the use of the unit insignia. Go figure. The decals were applied individually and treated with Walther's Solvaset to insure they snugged down tight. Once dry, a 2nd sealing coat of Future was applied to protect the decals during the weathering process.
    April 2005
Posted by wing_nut on Wednesday, March 3, 2010 5:49 PM
Had a few pages to get caught up on so I will keep it simple..
OH YEAH BABY!
Marc
    July 2004
Posted by wbill76 on Wednesday, March 3, 2010 6:03 PM
Simple works for me Marc! Thanks for the comments. Beer
    May 2005
Posted by terry35 on Wednesday, March 3, 2010 6:45 PM
Hi, Bill, great progress, lookingforward to seeing you sprinkle more magic weathering around.
Terry.
    October 2007
Posted by panzerguy on Wednesday, March 3, 2010 7:07 PM
  Bill finally got some time to catch up on this guy. Coming along great as always I see. Am I right that the nick name for the Nashorn was the 'door knocker'? Because that thing looks like it didn't even bother knocking! Just took the door right out of the frame along with the wall!
"Happiness is a belt fed weapon"
    July 2004
Posted by wbill76 on Wednesday, March 3, 2010 8:34 PM
Thanks Terry! The weathering process is something I'm looking forward to as well.
Steve, the nickname "Scheunter" was often applied to the Pak version of this gun and that may be what you're thinking of? I know the term "door knocker" was applied to the 3.7cm Pak but that was a derisive name since that's about all the effect it had on enemy armor. I'm not sure how "Scheunter" translates but it could definitely ring your bell at a distance! Wink
    November 2006
Posted by dupes on Friday, March 5, 2010 3:33 PM
Bill - "scheuntor" means "barn door". The crews of the Pak version called it that because it was as big, heavy, and maneuverable as, well, a barn door. Stick out tongue
    July 2004
Posted by wbill76 on Sunday, March 7, 2010 8:26 PM
I wasn't feeling too motivated yesterday so skipped working on the build for the day. I've found that when I get to the weathering stages if I try to force things I usually end up with a less than desirable result and today was a much better day so some progress was made although not quite as much as I'd planned for.
The first order of business was the overall application of a wash of MM enamel Raw Umber to the exterior of the vehicle. I use about a 90/10 thinner/paint ratio and apply the wash with a round 0 sable brush.
The wash dries pretty quickly but good ventilation is key due to the large amount of thinner involved. Next was the application of dot filters using MM enamel Flat White, Panzer Dunkelgelb, Deep Yellow, Raw Sienna, and Panzer Olivgrun. I applied small dots using spotter brushes and then used a square tip brush dampened with clean thinner and repeated downward strokes to work the dots until they virtually disappear. To remove thinner from the brush, I use an ordinary paper towel and touch the brush to it several times to avoid flooding the surface I'm working on and ruining the effect.
This process was repeated in small sections over the entire vehicle and took about 3-4 hours to complete. I worked in stages, all the while wearing a paint breather mask due to the large amount of time spent with thinner.
More weathering is yet to come in the form of a pin wash of Burnt Umber to pick out the details and also some pigment treatment to the lower hull and running gear.
    July 2006
Posted by redleg12 on Monday, March 8, 2010 5:21 AM
Bill  - it is never good to force it. You have to feel it, especially during the finishing stages......That's when it is best to have a nice glass of  Merlot and a good cigar and just think of Arnold.
Rounds Complete!!
    August 2009
Posted by M1Carbine on Monday, March 8, 2010 10:39 AM
Bill - BEAUTIFUL my friend the dot filering is spot on.
Bob
    August 2008
Posted by Pvt Mutt on Monday, March 8, 2010 12:12 PM
You've got me fired up Bill.Cool I spent several hours looking through my copy of Nuts &Bolts vol 14 and the new DML Nashorn kit yesterday. One problem, I want to build the Tamiya Wespe kit too. May have another twoofer situation here.Big Smile
Nice build again Bill
Tony LeeSmile
    July 2004
Posted by wbill76 on Monday, March 8, 2010 1:10 PM
Mike, sounds like some good advice! My wife and I went to go see "Alice in Wonderland" on Saturday and enjoyed it, not quite the same prescription as what you outline but close enough! Big Smile
Bob, thanks as always!
Tony, like you I also have the Tamiya Wespe in the stash that keeps calling to me. It will likely get built this year all things being equal as I've been putting it off too long! Glad to hear you're getting excited about the new DML Smart Kit, can't wait to see what you do with it. Beer
    January 2007
Posted by the doog on Tuesday, March 9, 2010 2:09 AM
Bill, I finally got back here in Armor--those darned MOPARS, you know....Whistling...and I like your paint job and presentation. A nice looking model, and another article-in-waiting, I'm sure?
Nice job, again!
