USMC M4A3 Dozer Riff Raff . Camera broke . No updates . 6/3
    March 2006
Posted by Shellback on Saturday, March 10, 2012 11:04 PM
Them holes for the sand shield bolts . Wonder what they did with the skirts and all of them bolts ? Hmm
Posted by T26E4 on Saturday, March 10, 2012 11:41 PM
Here are some online pics:
http://www.network54.com/Forum/110741/thread/1236618494/M4A4+with+Mine+Scarifier
Photobucket album
http://s45.photobucket.com/albums/f74/ericadeane/M4A4%20Scarifier/
It appeared in a Military Modelling issue in Aug '10? or so.
Roy Chow
Join AMPS!
http://www.amps-armor.org
    March 2006
Posted by Shellback on Sunday, March 11, 2012 1:49 PM
Roy , AWESOME build ! Yes I really appreciate you sharring the info and pics with me ...........Toast
I'm stumped right on the hydraulic hose that runs to the hydraulic cylinder on the blade.  Looks like there is only one hose and it must attach at the base .
Have you seen this video ? Its a fun watch.
http://www.youtube.com/watch?v=BV5nBQGn0w8
    July 2004
Posted by wbill76 on Sunday, March 11, 2012 4:55 PM
Moving right along with this one Carl, love the details you're adding along the way. Beer
    August 2006
Posted by K-dawg on Monday, March 12, 2012 2:03 PM
Very nice work so far!... Always a fan of the dozer!
Kenneth Childres, Central Arkansas Scale Modelers
    March 2006
Posted by Shellback on Monday, March 12, 2012 3:50 PM
Thanks everyone for your help and support .Yes
I started putting the blade together . The bottom part od the blade that is gray took a lot of work to get it smoothed out , The reason being that the poor is from this side and when i cut it off i missed up the surface . I rebuilt it with c.a. .When i sanded it smooth the i discoverd in point air bubbles . They were so smallthat a heavy coat of gray paint covered them .
    April 2009
Posted by deafpanzer on Monday, March 12, 2012 7:50 PM
Looking GREAT! Beer  Now you have been bookmarked.  You can't run, you can't hide from me... Indifferent
Andy
Posted by BaBill212 on Monday, March 12, 2012 8:04 PM
Me either,,,,  I'm with Andy,,,,,,,,,,,,  Yes  Beer  Yes
(great work Carl.............)
Enjoy the ride!
    March 2006
Posted by Shellback on Monday, March 12, 2012 8:37 PM
Ahhhhhh ............good to have my friends here !!!!!!  Toast
    March 2006
Posted by Shellback on Monday, March 12, 2012 11:04 PM
Scratched a "comb" and temporarily positioned the hydraulic cylinder .
    March 2006
Posted by Shellback on Wednesday, March 14, 2012 11:41 PM
These are the brass p.e. parts that will build into the support frame for the dozer arms. These will attach to the front two bogies on either side . The p.e. is .4 mm thick and is fairly sturdy but bends easily due to the precisely etched bending lines .
I made up these rods with the  heads on them to act as the fasteners that run thru the holes in the brackets . Their made from .025 styrene rod with the ends melted against a heated flat screwdriver blade toformthe head .
This is the support frame with the brackets glued on and one of the rods put in place to help line up the holes in the brackets .
All of the rods are in and glued here .
This how the support frame attaches to the bogies . I used .035 styrene rod  for the four mounting points . The holes in the p.e. was precise for a great fit on this Tamiya kit . Fitting these support frames on any other kit might be a hastle .I'll go back and shorten the rods in the bogie truck frames  later .
Now to the other side .
    March 2006
Posted by Shellback on Thursday, March 15, 2012 10:34 PM
Sand shield attachment strips on hull side .
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Friday, March 16, 2012 12:54 PM
https://encrypted-tbn2.google.com/images?q=tbn:ANd9GcRjyKqAgXaclZIlt_02HhUgLYyk4cDZvut6N5xzZLLgwVYDb633iUHS progress..........
 https://i.imgur.com/LjRRaV1.png
    March 2006
Posted by Shellback on Friday, March 16, 2012 4:00 PM
Thanks Steve ! Yes
    January 2006
Tamiya M4A3 with Verlinden M1 dozer ............wip .
Posted by SprueOne on Friday, March 16, 2012 10:17 PM
nice progress AND from your build I'm learning how the 1/1 was built Idea Yes
Tags: bulldozer
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    March 2006
Posted by Shellback on Friday, March 16, 2012 11:29 PM
Thanks Yes
I didnt want the "duck bill " extensions on this Sherm . The kit provids rubber band tracks  with the extensions . I ordered a set of "workable " tracks from Bronco ..............but they do not fit the Tamiya drive sprocket teeth . On a side note they do fit the Italeri drive spocket perfectly . I havent tried them on my Dragon M4's yet .
The Tamiya kit tracks .
After the extensions removal .
    July 2004
Posted by wbill76 on Saturday, March 17, 2012 11:54 AM
Nice bit of surgery there Carl. Would never know they had extensions if you hadn't shown the before pic.
    March 2006
Posted by Shellback on Saturday, March 17, 2012 3:19 PM
Thank you Bill Yes
    January 2011
Posted by fificat on Saturday, March 17, 2012 5:25 PM
Shellback--Why not just use the Italeri sprockets with the Bronco tracks?
    March 2006
Posted by Shellback on Saturday, March 17, 2012 5:58 PM
fificat
I concidered doing that . Then i looked at the Italeri spockets . They have the "axle" as part of the drive sprocket where as the "axle" on the Tamiya kit is part of the hull . I know it can be done and maybe you have done it but i didnt want to do it on this build . Then there is that big "sink hole" in the middle of all of the Italeri M4 drive sprockets . I just didnt want work with them .
    September 2009
Posted by satch_ip on Sunday, March 18, 2012 8:55 AM
Very curious to know if the Bronco tracks fit the Dragon kit.  Be sure to post that when they come, please.
Satch
    January 2011
Posted by fificat on Sunday, March 18, 2012 10:58 AM
Take a look at this re the Bronco tracks.  Shows they fit the Dragon sprockets very nicely, and notes that the Tamiya ones can be repaired.
http://www.perthmilitarymodelling.com/reviews/vehicles/bronco/ab3538.html
    March 2006
Posted by Shellback on Sunday, March 18, 2012 2:16 PM
CORRECTION ! Hey guys i went back and tried the Bronco tracks on the Tamiya drive sprocket again . With some sanding / filing on the edges of the Tamiya sprocket i was able to "force " the Bronco's around the Tamiya sprocket . It felt like the Bronco's might break but they are stronger than i would have thought . Mind you they actually just fell into place around the Italeri sprocket so "forcing "them around the Tamiya sprocket was difficult to accept . But for the sake of research and not mis-leading you guys i went ahead and adjusted the Tamiya sprocket and got the bronco's on .  fifcat , thanks for taking an extra look and doing the research !Yes
On the Tamiya sprocket .
Here's the Bronco's i have , T-49's .
As you can see the "pins" are delicate looking .
    March 2006
Posted by Shellback on Sunday, March 18, 2012 10:36 PM
Here's an update on how i mounted the support frame for the dozer blade arms . I wanted the entire dozer blade and its support frame removable for painting and weathering .
The fit is tight and no gluing is required for now . I may leave it unglued after painting and weathering .Yes
    March 2006
Posted by Shellback on Tuesday, March 20, 2012 2:10 AM
I drilled holes in the pivot points of the dozer arms and in the support frame and inserted "pins" that i made from styrene rod .
    July 2003
Posted by disastermaster on Tuesday, March 20, 2012 12:40 PM
https://encrypted-tbn3.google.com/images?q=tbn:ANd9GcQQaAxP-VvZ0Ub_qldve4WB2erUKgMCN6B8VJ8xJ_1KG7pfaZ09I_UPwQ  A DEFINITE  bookmark Carl.
                              I'm a watching.
    March 2006
Posted by Shellback on Tuesday, March 20, 2012 2:46 PM
Hey Steve , great to have you following my build !Yes
    March 2012
Posted by Dano on Tuesday, March 20, 2012 2:51 PM
 Great detail work. I have the Academy version on the bench. I'll be taking notes...Big Smile
 Those Bronco tracks are a seemingly never ending task....Indifferent
    August 2006
Posted by ogrejohn on Tuesday, March 20, 2012 3:58 PM
Great looking work Carl!
Posted by BaBill212 on Tuesday, March 20, 2012 4:11 PM
Yes  Yes  Beer Beer Beer        as always Carl,,,,   good stuff!
Enjoy the ride!
