Super Detailing an AMT Star Wars Snowspeeder
    October 2003
Posted by modelmaniac1967 on Sunday, March 29, 2009 2:50 PM
 Division 6 wrote:
Look at what I just found.
Eric...
Oh SWEET love the speeder cross sections....
Life is an illusion, if you can master the art of illusion you have it made.[View:http://sdfusioninc.blogspot.com/]
    October 2003
Posted by modelmaniac1967 on Sunday, March 29, 2009 3:57 PM
Wow that is amazing, without ever seeing that cross section of the engine for the speeder I came out pretty darn close with what I have come up with.
    October 2003
Posted by modelmaniac1967 on Monday, March 30, 2009 4:52 AM
I have a lot of detailing to do on the inside with the engines, but i did a lot of work done on the cannon and tow cable. I re-did the port where the cable goes in through the heat fins....I built a square tube to fit the panel, and wound wire around piano wire for the coils and inserted the piano wire thru the tube, then inserted that into the heat sink part.
This probably will be all I can do for this weekend. Will give updates however if I get time to work on it at all this week, have a very heavy work week so may not be able to touch it...
Side note: The project will take even longer now as I have decided tonight that I need to rebuild both sets of supports that hold the long guns on either side of the t-47. I am not happy with the detail and to hinge the air brakes it just wouldnt look right from the kit parts, so all of that has to be scratch built.
As well as a complete compartment where I put the engines at. Its too void with out any bracing and I want to make it match the front two panels.
    February 2007
Posted by PetarB on Tuesday, March 31, 2009 4:42 AM
Amazing work, keep it up!!!
www.studiostarforge.com
    October 2003
Posted by modelmaniac1967 on Tuesday, March 31, 2009 6:42 AM
Thank you, I won't be stopping on this anytime soon. I have become obsessed with this one!!!
    October 2003
Posted by modelmaniac1967 on Monday, April 6, 2009 4:39 AM
A little update, didn't get much time to work on it this weekend but opened up the foot hold holes, devised hinges for the airbrakes, begun to work on a plan for inside that same compartment,  and made a compartment where the fuel tank goes on the front of the speeder. Im thinking of adding resistors and calling them fuel cells....
Of course would have a lot of piping and wires and things in there as well...
    October 2003
Posted by modelmaniac1967 on Monday, April 6, 2009 6:46 PM
Had a little time this afternoon before going into work tonight and attached the hinge for the other airbrake and finalized the layout for the fuel cells on the front compartment.
    September 2006
Posted by aussiemuscle308 on Monday, April 6, 2009 11:02 PM
That some beaut scratchbuilding in there.
    October 2003
Posted by modelmaniac1967 on Tuesday, April 7, 2009 5:38 PM
Thank You I have never really scratch built before so im kinda amazing myself on this build. Not that im doing much scratch building, i should state that Im adding some scratch built items to a kit.
    October 2003
Posted by modelmaniac1967 on Tuesday, April 7, 2009 5:41 PM
I cant get too close with my camera (i apologize for the crappy photos) , but this is a basic layout for the inside of the air brake compartment. Ill add a ton of wiring to all the components...
    January 2009
Posted by Division 6 on Tuesday, April 7, 2009 6:04 PM
Looking good my friend.
I sealed mine, didn't want to deal with re-detailing them.
At first I was going to have the covers removed than just decided on the easy way out.Whistling [:-^]
Eric...
    October 2003
Posted by modelmaniac1967 on Tuesday, April 7, 2009 6:12 PM
Eric...
Thats what I had planned to do was seal them. Then i thought i have gone so far with it just keep going, just have to figure out a way to hid the hinge attachments on the upper door. The only regret i have now is opening up the bottom panel because if it sits on a dio base, no one will see the detail, I may just cover that up and not finish the engine part, Unless i can come up with a creative way of having it in flight Ill just cover that panel back up.
    January 2009
Posted by Division 6 on Tuesday, April 7, 2009 6:35 PM
What about having it up on some sort of lift so you can see underneath.
Don't know what your diorama idea is but you could do it like a show car with mirrors under it.
Eric...
    October 2003
Posted by modelmaniac1967 on Tuesday, April 7, 2009 7:41 PM
Eric...
Haven't gotten to the base ideas yet, althought now would be a good timet to start. The mirror thing is good, as soon as I read your suggestion a futuristic type of fork lift came to mind, but then again i would have to build that thing 100% from scracth and thats way beyond my caliber. Mirrors just might do it.
    January 2009
Posted by Division 6 on Tuesday, April 7, 2009 8:09 PM
For a lift I was thinking of something like auto shops put your car up on with to runners that the body would sit on.
Could even put a pit under it with a mechanic or droid.
Eric...
    October 2003
Posted by modelmaniac1967 on Tuesday, April 7, 2009 8:37 PM
Eric...
Hey that would work. Yeah I know what your talking about as far as the lifts go. That all could be built real easy out of square and round tube. There you go I like that idea. Will throw ideas around on that one.
    January 2009
Posted by Division 6 on Tuesday, April 7, 2009 8:40 PM
Quick sketchBig Smile [:D]
Eric...
    October 2003
Posted by modelmaniac1967 on Wednesday, April 8, 2009 4:50 AM
Eric...
 Love the sketch your an excellant artist as well. I LIKE IT. That will probably be the way I go with the dio. That will solve the whole bottom view of the speeder. Do you know off hand what scale this speeder is? I looked all over the box and instructions and couldnt find a reference to scale. As the droids may have to be built from scracth...
    January 2009
Posted by Division 6 on Wednesday, April 8, 2009 5:27 AM
Most references I have seen say it's 1/25 scale althought no one knows for sure, one even said 1/35.
I scaled it at 1/22 off a measurment I found and the figures I got are 1/20, compared to photos of the set ships they look close.
The only diffirence is maybe a 1/16 to 1/8 inch.
The action figures are to big by about 1/4 inch.
There are 1/25 scale mechanics for race car dioramas available since it's a common car model scale.
Eric...
    October 2003
Posted by modelmaniac1967 on Thursday, April 9, 2009 5:56 AM
Ok got a little done yesterday afternoon. Almost done with this part of the speeder, now just to make this side match the other side....
    October 2003
Posted by modelmaniac1967 on Thursday, April 9, 2009 6:00 AM
Eric...
Figures probably not as I suck at painting figures, I like the droid idea or I could just in a pinch leave it on the lift as if everyone was on a break, could even name the dio "break time" and that would explain why no one was there....
    January 2009
Posted by Division 6 on Thursday, April 9, 2009 2:14 PM
Don't back out now. lol
Make a bunch of droids doing the work and or some aliens.
Eric...
    October 2003
Posted by modelmaniac1967 on Thursday, April 9, 2009 9:11 PM
Eric...
Yeah I was thinking today about building some droids, kinda like the pit droids or the droid that solo had on his falcon that he said "check it on the other end", that was mostly a "stick" shape droid that would be easy to build several of those...
    January 2009
Posted by Division 6 on Thursday, April 9, 2009 10:47 PM
It's called a Treadwell.Wink [;)]
    October 2003
Posted by modelmaniac1967 on Friday, April 10, 2009 1:53 PM
Treadwell, would be easy to make them in plastic. I may go that route.
    January 2009
Posted by Division 6 on Friday, April 10, 2009 2:23 PM
Body of the Astromech (R4) is 18" dia.
    October 2003
Posted by modelmaniac1967 on Saturday, April 11, 2009 9:13 AM
I like the treadwell for ease of building. It would be nice if the speeder was a scale to match the action figures but oh well.
    October 2003
Posted by modelmaniac1967 on Saturday, April 11, 2009 9:14 AM
No real updates except i finished matching the detail in the airbrake cavity, so those parts are done. Now to concentrate on the engine bay and the front feul cell area...Then time to engineer some seat belts, scribe lines, and start think about a paint scheme......
    March 2006
Posted by TD4438 on Sunday, April 12, 2009 8:28 AM
WIPS = TEASE
Boy I can't wait to see this baby complete.
    October 2003
Posted by modelmaniac1967 on Monday, April 13, 2009 2:22 PM
 TD4438 wrote:
WIPS = TEASE
Thank you, and everyone else who is following me on this build. I am getting very anxious as well to see this thing thru, and finished. I got more done last night and will post pics of the progress this afternoon or evening...
