For the sake of an update... things I am working on:
1. Aquaman is coming along so so. The good news is that he will fit into the chamber. I figured it pretty well. It's a tight fit but so is the actual movie prop.
Adding detail to the figure has been problematic. I can't figure a medium that is workable and dries hard. I tried using both sprue-goo and Apoxie Sculpt. I had limited sucess with the goo, and sculpt, forget about it. Apoxie Sculpt is good stuff but as a sculpting medium, it sucks. It is very difficult to use. It sticks to your finger or tools more than to the piece you are applying it to. And the stuff doesn't smooth out very readily. Once you get it stuck to the piece--you must press with superman force in order to flatten it out. Wetting it helps, but it's still a battle. The beauty of the stuff is its dry state. It sands, drills, and bonds well, once cured.
I may try this again, maybe using thick CA. The goal is to make a master copy so that I can make a mold to recast 4 figures.
Anyway--like I said in another post--the figures will be crude. And that is Ok because a person won't see much of the detail anyhow. Just having a 3D represention in there should look cool. The crappy one I made thus far did.
2. I applied Apoxie Sculpt to the roof of the cabin leading down towards the top of the window frames. It is a sort of headliner. The movie prop had something that when viewed from the back, the top of the window frame can't be seen. I tried to mimic that. It was a battle using sculpt but I think it's shaped nicely and to good effect.
3. The lower chambers were missing bottom panels. Those are needed to rest the beds on. I cut, fit, and installed those panels.
THE END
