BOW HEADS AND RAILS
To put it simply, the bow heads and rails in the Revell kit are atrocious. Force9 came up w/ a nice solution for the supports between the rails, but I thought I would go one better and build them from scratch using the BlueJacket plans. I had ordered their britanica metal rails and already had the PE for the grating and the heads. Well....the bow of the Revell kit just does not match up w/ the Bluejacket model. The PE grating did not come anywhere close to fitting, and the rails just did not look right scale wise. I did attempt to use them anyways (the rails) and after many hours of exasperating trial and error finally gave up and decided to go w/ the Revell kit pieces w/ some modifications.
I cut out the existing two, way out of scale, heads from the grating and fitted the BJ PE heads in its stead. Strictly speaking, they are not correct for the time frame that I am attempting to stage the model in, but sometimes you end up sacrificing accuracy for appearance.
This means that I also won't be able to use the forward boomkins w/ out some fairly serious refitting, but the BJ plans do not call for them, and as they are a part of the running rigging that I do not intend to include, no great loss. I guess I can always go back and figure something out later if I need/want to.
I ended up painting the two top rails solid white as the detail just did not come out on those pieces. There is a bit of 'corrections and touch up to do, but they came out satisfactorily enough. Note that I also "fleshed out" the hawse ports w/ some chain links that I picked up at the local craft store to meet the specifications that I outlined at the beginning of this log.
The carronades are coming along very nicely, but excruciatingly slow. I figure I am averaging about two hours per gun. It is much more tedious and difficult than I would have thought.
Axiom: It's a good idea to know how deep the water is before you jump in.
The way they are now will be their final fitting (version 4.2). I went back and added a "bridle ring" for the breech rigging to pass through by using some crimping beads that I had. They are just a little bit larger than scale, but still look soooo much better and more accurate.
The cordage comes from Syrene, where I ordered my blocks from. Pretty expensive stuff, but I finally got the right sizes w/ out having to build my own rope walk. I really need to finish these before I can place the pin rails, so it may be a while before I post again.
