100th Anniversary of WWI GB
    October 2008
Posted by Rigidrider on Wednesday, August 27, 2014 4:43 AM
LOL... Well, Maybe she stopper to "Kill" her catch, or to take a bite, For all I know the rest may be in the tree. When fall arrives and the leaves drop, I'll look some more. LOL...,
Doug
When Life Hands You A Bucket Of Lemons...
Make Lemonade!
Then Sell It Back At $2 Bucks A Glass...
    January 2014
Posted by Rob S. on Wednesday, August 27, 2014 5:41 AM
Marcus - those barrels are looking great. They certainly add great realism to the build.
Doug - Well, the hawk certainly won, eh? Looking forward to your next build (protected from predators I bet Stick out tongue)
Blue - that Eindecker cowling looks great. When I did that plane I did the recommended method from the website. It looks ok, but, I like your results better!!
______________________________________________________________________________
On the Bench: Nothing on the go ATM
    January 2014
Posted by Rob S. on Wednesday, August 27, 2014 5:53 AM
Got some more progress on the Roland. Managed to get the entire first phase of the build done: cockpit and engine bay.
Here's the plywood backed seat and rear fuselage cover:
Instrument panel:
Previous assembly (fueltank/MG magazine etc) fitted (perfectly cuz WnW is AWESOME, btw!!) with ribs, rear fuselage cover and front engine mounting rails:
VERY hard to see except this way: the control cables (EZ Line). Took Sasho's advice and pre-attached the lines before closing up the sub-assemblies - saved LOTS of stress!!:
Lots of work done so far and overall happy with what's happening. Need to yet install the PE seatbelts, but, waiting for the oil paint to set up better on the seat. Going to tackle the engine starting today.
    October 2013
Posted by Big Blue on Wednesday, August 27, 2014 8:32 AM
Marcus: Those barrels look great, I am sure they are a big improvement over the plastic kit parts.
Rob:  Your Roland continues to impress.  I love the wood work you've done on the seat.  What technique did you use to produce the grain pattern?
Lots of good eye candy continuing to come out of this group build!
    January 2014
Posted by Rob S. on Wednesday, August 27, 2014 9:09 AM
Hey Blue, thanks, that was artist oil burnt umber over Vallejo wood. I used a course brush to drag across the surface then worked the fine details with the tip of a blunted toothpick.
    October 2008
Posted by Rigidrider on Wednesday, August 27, 2014 10:55 AM
Excellent pit Rob! Really nice, yes the next build will not be exposed to the dangers of the great out doors!Lol...
Doug
Make Lemonade!
    June 2010
Posted by rocker286 on Thursday, August 28, 2014 9:48 PM
Wow guys, everyone's doing such an awesome job on their builds, it's great to watch the these aeroplanes/warships/tanks/etc come together with each new photo! I've made a bit of progress on my Nieuport tonight. I even took a rotary tool with the smallest bit I could find to the cowling. In my research for this build, I found out that the Revell kit did not include two cooling vents on the underside of the cowling- and rather than try to track down a resin replacement part that has since gone out of production, I did a little body work on my Nieuport. I've since glued on the engine, cowling, stabilizers, rudder, machine-guns and windshield. Soon I'll spray primer on it and tackle that awesome French camouflage ! DSCF1502 DSCF1505
4badges
    October 2013
Posted by Big Blue on Friday, August 29, 2014 8:38 AM
Rocker: It looks like you have made some major headway on your Nieuport.  I'd love to see some detail pictures if you have any.
I re-did the metal work to match the cowling, and painted the fabric interior cockpit walls.  I used a base coat of the fuselage color (XF-22), followed by a very light and uneven coat of Deck Tan (XF-55) since I figured the doped exterior wouldn't come through the linen perfectly evenly.  I used some dark pigments for stains, and Tamiya Smoke (X-19 ) to give them an oily shine.  Finally, the details in the metalwork got a grimy oil wash to give them some separation.
One last look before buttoning up...
As the picture shows, none of the color variations in the "fabric" can really be seen once the cockpit is in place!  Oh well, I feel better knowing they are there.
The fuselage is closed up, and waiting some touchup work on seams.  Even the best engineered kits in the world can't prevent me from creating visible seams!  I have also started assembling the resin engine... did I mention the parts are tiny?!  I hope I am up to the challenge!
Keep up the good work everyone,
Blue
    January 2014
Posted by Rob S. on Friday, August 29, 2014 10:22 AM
Blue..awesome. Now, that`s something I never thought to do with my E.III - the metalized interior. Looks fantastic. What are your turnbuckles made from or AM parts? Thanks
    October 2013
Posted by Big Blue on Friday, August 29, 2014 11:55 AM
Thanks, Rob. I have seen reference photos that show the finish on the interior metal, as well as some where it doesn't seem to be the case.  I didn't give the aluminum ammo box a swirled finish, but figured that if the purpose was anti-corrosion, it probably made sense that the interior walls would be treated.
My turnbuckles are made from Albion aluminum slide fit tubing colored with gold Sharpie like so:
I originally tried using Gaspatch turnbuckles (which I will be using for the exterior rigging), but it just looked too crowded in that small area, so I improvised.  After I got it all rigged, I realized that in most of the reference pictures I have seen, the turnbuckles have some protective covering over them, so perhaps a different approach would have been warranted:
Blue
    April 2006
Posted by waynec on Friday, August 29, 2014 12:55 PM
some great airplane building going on here. looking at it makes me want to move all my ww1 airplane stash to the garage get rid of area.
made a better base for ww1 tank. the ground is a mixture of coffee grounds and charcoal ash.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    October 2013
Posted by Big Blue on Friday, August 29, 2014 2:28 PM
Looks nice, Wayne.  I have yet to attempt a base for any of my models, but it is on the to-do list.
I'm willing to bet that your aircraft builds would turn out better than my attempt at armor would!
    April 2006
Posted by waynec on Friday, August 29, 2014 3:41 PM
Big Blue
hey blue i don't think so BUT i would be willing to do an airplane OR helicopter if you do a tank. this sounds like it could be an interesting albeit small GB in the future.
how do we decide? i have a few helos including a couple of 1/35 BLACKHAWKs and a number of 1/72 4 engine aircraft. the 1/32 BF-110 might be a bit much.
    October 2013
Posted by Big Blue on Friday, August 29, 2014 3:53 PM
I'll give it some thought Wayne, but have a stack of biplanes to work through first!  There is a fine line between a stash, and a wife-distressing pile, and I am trying to stay on the right side of it.
    April 2006
Posted by waynec on Friday, August 29, 2014 4:10 PM
Big Blue
i have a bunch of GBs too so not before the first. i would do something for the GROUND ATTACK GB. if you can still fit both cars in a 2-car garage you're ok.
    February 2005
Posted by 65ss on Sunday, August 31, 2014 9:11 PM
Rob that "pit" looks great, I really like the wood grain!
Rocker I can't wait to see that cammo!
Wayne that base sure does set that tank off nicely!
Blue Your "pit" is also looking great!
Now I have a question for all you biplane guys-how can you see to do all that great detail work? I don't think my eyes would be up to the task anymore!
Dale
    October 2013
Posted by Big Blue on Monday, September 1, 2014 7:56 AM
Dale: I can't answer for the others, but I can tell you my eyes aren't up tot he task anymore either!  I bought a cheap pair of 3x magnifier reading glasses at Walmart... dirt cheap, but they work.  Takes some getting used to, but once you get the hang of it, they make a big difference.
I have 1.25 readers for, you know, reading, so I wind up swapping back and forth as I swing over to the computer to check a reference photo or the like.  I'm sure its pretty humorous to watch me....
    January 2014
Posted by Rob S. on Monday, September 1, 2014 8:11 AM
I've always been nearsighted...can't see finer detail on the TV from my hobby bench, but, for some reason, never needed correction close up. That Roland 1/32 pit is quite larger than an entire 1/72 fuselage, so, for me the scale is gigantic!!
    February 2006
Posted by ruddratt on Monday, September 1, 2014 8:20 PM
Wanted to check in and see what you fellas have been up to, and brother am I impressed!!
Blue, the Eindecker looks better with each update ( that 'pit looks so real I'm tempted to climb in and take 'er for a spin),  and I'm gonna have to try your turnbuckle method too - good stuff!
Rob, it's been a lot of fun watching your progress on the Roland.  That 'pit looks top notch, especially the woodwork.  Thinking I may have to pull mine off the shelf for this GB when the Tripe is done.
Rocker, great stuff with the Nieuport.  Would love to see some close-ups of the 'pit and the engine if you got 'em.
Wayne, excellent work on the base.  Groundwork is not my strongpoint - wish it was, because it adds so much to a model.
Work has been steadily progressing on the Tripe.  The engine is done and the fuselage buttoned up with the lower wing attached.  Should have some pics up either later today or tomorrow.
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    September 2011
Posted by falconmod on Tuesday, September 2, 2014 6:46 AM
Got a little more work done on the Albatros.
painting the green tail feathers and gray body is next.  Surprise
John
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
    October 2008
Posted by Rigidrider on Tuesday, September 2, 2014 3:37 PM
Alright friends... after all the BS with my build disappearing I finally got to start the 1/48 Roden Fokker DRVII.
Man, even in 1/48, its small to the SPAD. (1/28th) But I have another SPAD ordered and it looks like plenty of time to complete, so, Heres the little Fokker...
Not a whole lot done this weekend, but some of the main components...
Doug
Make Lemonade!
    February 2006
Posted by ruddratt on Tuesday, September 2, 2014 10:15 PM
John - very nice work on the Albatros.  WWI birds had some very colorful plumage,  and the Albatros just may have led the pack when it comes to that catagory.
Doug - nice to see ya back in the saddle.  I love the D.VII and will be watching this one closely,  especially since I've yet to build Roden's D.VII (just WnW's and Eduard's so far).  I really like what I see so far on this one! Yes
    October 2008
Posted by Rigidrider on Wednesday, September 3, 2014 4:56 AM
Thanks... its a nice kit, but I forget that these were not large aircraft and to me its more along the scale of a 72nd scale in comparison.  The instructions are at times a tad confusing, so alot of dryfit and second looks are required, ha,  It wont be highly detailed above and beyond the nice detail already built into the molds, but I think its a good kit.
Doug
Make Lemonade!
    September 2011
Posted by falconmod on Wednesday, September 3, 2014 6:37 AM
And let the 1/72 scale rigging begin! Bang Head
Should be a blast!  lol
John
    October 2013
Posted by Big Blue on Wednesday, September 3, 2014 7:54 AM
John: The albie looks great, I can't imagine trying to rig at that small a scale.
Doug: Nice to see you back in the saddle, as it were.  It looks like you've made a great start.  I have a 1/32 D.VII waiting for me when I finish the Eindecker.
Mike: Thanks for the supportive comments, they are always appreciated.
I have made some further progress, and will get pictures posted soon.  Keep up the good work all!
Blue
    October 2008
Posted by Rigidrider on Wednesday, September 3, 2014 11:24 AM
Thanks Blue... I love the eindecker! Might just try to build one some day, its just that Ive never really had alot of experiance with WWI aircraft.
Doug
Make Lemonade!
    April 2005
Posted by wing_nut on Wednesday, September 3, 2014 6:54 PM
xxxxxxxxxxxxxxxx
Marc
    April 2005
Posted by wing_nut on Wednesday, September 3, 2014 6:59 PM
Something wrong... Can't post properly. When I type out the post all the spacing and formatting is gone an it's all compressed into a single paragraph. Words, image file, links... everything. The buttons at the top to insert images, make links etc are gone. Anyone else having this problem. To see if it happens again this post has 4 parts separated with spaces.
Marc
    April 2005
Posted by wing_nut on Thursday, September 4, 2014 7:20 AM
OK... got allthat other crap sorted out.
I am finally ready to join the fun here.  I went back a bunch of pages to get caught up and there's lots of top notch working being done 'round here.
Here's a link to the WNW birds that I had to start to early to qualify here.
http://cs.finescale.com/fsm/modeling_subjects/f/2/p/160198/1763147.aspx#1763147
With those done the Harry Tate is on the bench and ready tog o.
Marc
    October 2013
Posted by Big Blue on Thursday, September 4, 2014 7:32 AM
Glad to see you get started here, Marc.  Your Snipes came out great.
Blue
