"Century series Jets" GB 2014-2015 * CLOSED *
    August 2014
Posted by mailwalker on Saturday, May 16, 2015 8:56 PM
Thank you, Thuens.
Here is my update on my progress. I do need to touch up some spots where the camo pattern meets. My question is, can I do this acceptably with a brush, or should I remask those areas and spray them? Also I noticed the lighter green did not coat as well in some areas, so I have to fix that! Any comments or input always welcome.
It doesn't matter that you ARE the best, but that you DID your best!
    January 2014
Posted by Rob S. on Saturday, May 16, 2015 9:53 PM
IMO, because you have 'hard edged' cam, I'd have no issue touching up with a brush.
______________________________________________________________________________
On the Bench: Nothing on the go ATM
    March 2010
Posted by mach71 on Saturday, May 16, 2015 10:04 PM
Looks nice mailwalker. I really like the heat disconsolation effect.
FWIW I agree with Rob, a fine brush should work well.
    August 2014
Posted by mailwalker on Sunday, May 17, 2015 8:09 PM
Thanks Mach and Rob.
I'm calling the camo done, now just mask and paint  the external fuel tanks. And here is a rookie question, how do I glue two painted parts together? Do I remove the paint from the attatchment points? For instance the bomb rack to the under wing. Thanks for the help.
    April 2010
Posted by Theuns on Monday, May 18, 2015 9:46 AM
Ideally you need a raw plastic to have the glue fuse the two together, otherwize it might not make a good bond.
Nice work on the camo :-)
Theuns
    January 2014
Posted by Rob S. on Monday, May 18, 2015 10:17 AM
Exactly what Theuns said. The cement can't 'cement' the plastic together (essentially, chemically melt the two pieces together) when the paint obscures the surfaces. Interestingly enough, you can't really glue much 'paint to paint' with most adhesives, even CA glue.
    July 2014
Posted by modelcrazy on Monday, May 18, 2015 12:00 PM
That has happened to me on several occasions. The CA just attaches to the paint and the paint comes right off the plastic.
Steve
    February 2010
Posted by 68GT on Monday, May 18, 2015 4:06 PM
If I cant get a good plastic to plastic contact I will just use Titebond.  It's a white glue type wood glue used for molding and trim.  I picked it up a few years back when I was heavily into building model rockets.
The Hun looks real good otherwise.
I had a small setback with the Six though.  When I set the decals on the fuselage I didn't notice that the extra blue with white stars over the cockpit was to go over part of the canopy.  I trimmed it and chucked it.
 I was trying to match the blue when I noticed my mistake. I have some scraps left over so I'm going to spray the back of the canopy white and pray the scraps cover it.  The stars on the decals were actually clear and not white so I have to try this.
On Ed's bench, ???
    August 2014
Posted by mailwalker on Monday, May 18, 2015 4:20 PM
Thanks Thuens, Rob S., modelcrazy, and  68GT.
68, sorry to hear about the decal catastrophe, hope it works out.
    December 2013
Posted by CodyJ on Monday, May 18, 2015 8:34 PM
Hey Folks.  Only 13 days left it looks like.  I'm gonna be crazy and throw this in, if I may.  Its a 1/144 F101.  I'm building it for a display for a friend and was glad to see a GB it can fit into.  Thanks Gents!
    January 2014
Posted by Rob S. on Monday, May 18, 2015 9:02 PM
Right on Cody...welcome!
    April 2010
Posted by Theuns on Monday, May 18, 2015 11:09 PM
Nice to see it in 1/144 :-)
Theuns
    December 2013
Posted by CodyJ on Tuesday, May 19, 2015 1:17 AM
Thank You Gents!
Oh man this thing is a bad bad kit.  Sad  The plastic is VERY VERY brittle and lacks any details whatsoever (The cockpit is closed off even!).  I did cut the cockpit open however.  Oh well, I'll press on and see what happens!   I think the brittleness is the worst part.  Hardly any pressure from a knife want to tear the plastic off in bits rather than cut.  Its a new blade too!   Switched to sanding off the sprue joints.  That is working well.  I doubt the knife will come into play much in this build.
    December 2003
Posted by scottrc on Tuesday, May 19, 2015 8:18 AM
Welcome Cody, we can always use another VooDoo.
    February 2010
Posted by 68GT on Saturday, May 23, 2015 10:48 AM
Not looking bad.
On Ed's bench, ???
    March 2010
Posted by mach71 on Saturday, May 23, 2015 11:18 AM
68GT Your dart is heavenly. ;-)
Looks great
    August 2014
Posted by mailwalker on Sunday, May 24, 2015 6:05 PM
68GT, your build is looking really awesome!
Here is an update. My first decal application in 20+ years or so. These decals are nothing like I remember, laying right down. Plus Microset and Microsol, something I had never heard of until getting back into modelling with this build. The decals are Caracal and Aeromaster.
A little background for this is that I am making this as the craft my uncle crew chiefed in Viet Nam (Triple Nickle). The H and P and each 5 are all individual decals, nerve wracking for me as a rookie. I hope Uncle appreciates this.
    March 2010
Posted by mach71 on Sunday, May 24, 2015 7:36 PM
Looking really good!
    April 2010
Posted by Theuns on Sunday, May 24, 2015 11:37 PM
Indeed!
Theuns
    February 2010
Posted by 68GT on Monday, May 25, 2015 2:04 PM
Been a long time coming but I think we're done.
Hasegawa 1/72 F-106A, Jacksonville ANG
On Ed's bench, ???
    August 2014
Posted by mailwalker on Monday, May 25, 2015 8:10 PM
68GT, that looks suhweeet!
Here's my update for the day. Right side of "Triple Nickel" all decaled.
    January 2014
Posted by Rob S. on Monday, May 25, 2015 8:15 PM
68...got yer lovely posted up front...well done and thanks for the inspiration for mine...some day I'll get to it..Anyway, very cool, great job!! YesCoolYes
    January 2014
Posted by Rob S. on Monday, May 25, 2015 8:18 PM
I just gotta say it...that is one impressive looking front page...These builds have been epic..What a great build this has been!! Great job so far guys!!
    December 2012
Posted by flyerduke on Monday, May 25, 2015 8:53 PM
GT -  That's one slick lookin' airplane.  Great job.
MW - Almost there.  Looks good.
Craig
    April 2010
Posted by Theuns on Monday, May 25, 2015 11:32 PM
Dang that 106 looks good, well done on a very impressive decal job!
Thanx for taking part :-)
Theuns
    February 2010
Posted by 68GT on Tuesday, May 26, 2015 6:19 PM
Thanks, I just wish I was able to get started on the pile of Monogram 6s I have.
On Ed's bench, ???
    January 2011
Posted by Tal Afar Dave on Thursday, May 28, 2015 6:39 PM
Great work on the first page gentlemen; you've done the 'century series' proud!!
It does not look like I will complete my build on time; I bit off more than I could chew by going back to school and overloading on too many classes.....oh well.  It's been fun just to watch from the sidelines......
Let's go Mail walker; finish up strong!!
Dave
2022 New Year's Resolution:  Enter 1 group build and COMPLETE a build this year!!  Why Photobucket did you rob me of my one Group Build Badge???  Must be part of the strong anti-Monogram cartel!!!
    April 2010
Posted by Theuns on Thursday, May 28, 2015 11:46 PM
Dave, nothing wrong with setting prioreties correct mate - school = $ to be able to buy more models ;-)
How much time do you need to complete?
Theuns
    March 2010
Posted by mach71 on Friday, May 29, 2015 9:11 AM
Tal Afar Dave, I would love to see your build even if you don't finish on time.
School is much more important.
Mailwalker, Your almost there! Looking forward to seeing 555 finished!
    August 2014
Posted by mailwalker on Friday, May 29, 2015 8:25 PM
Almost got it. Everything but the wheels, pitot,  leading wing flaps and fueling boom assembled. Just gotta get them on and spray top coat. Thanks to everyone for your patience!
Not to sure about weathering, as that is something new to me and I don't want to mess up what I've got so far.
