Okay, for anybody still watching...I'm about to mad dash this SOB to the finish line!! Here's a few last things I managed to tie up this -A before priming.
I redid the MG barrels with albion brass tubes. I'll be doing something similar for the -D. I saw Lawdog do this a while back and it seemed a whole lot better and cheaper than another AM part. The picture collage is fairly self-explanatory. I glued a 3/32" plastic tube to receive the albion tube combo. This allows me to paint them separate and close up the wing now. A lot easier for cleaning up these seams and saves me masking this part later. =]
Untitled by Britt Vallot, on Flickr
The prop for this kit in reviews I've seen in the past looked really big to me. This one here came in a different color plastic than I've previously seen and this particular prop doesn't appear as bad, but...still pretty thick for my taste. So I got to sanding. Here's the difference.
In the top two frames the top blade is the original unsanded part compared with the two I've sanded. I based them off a Squadron walkaround for Allison engine Mustangs. The bottom left frame shows the thickness of the blade while the bottom right shows the corrected scale thickness (as best as I could make). So in just a few minutes I've gone from a boat oar that you'd paddle with, to a pretty sharp looking prop fit for a Mustang. =]
I did my usual elevator piece which was the same as the Tamiya kit...a one piece...much less fuss. The elevators slipped down in the -As just as they did for all Mustangs.
I've riveted the plane, but it's pretty much the same. I try not to go too heavy with pictures. You can kind of catch it in some of these pics.
I opened the radiator scoop a little wider. The opening is now a better fit to the kit part and there's no plastic protuding into this space...and you can see the radiator front that I built way back. =]
And here's just a quickie of where I'm at before priming with these two.
Tomorrow, Paint!
