RAF 100th Anniversay GB
Posted by Gamera on Thursday, May 11, 2017 8:58 AM
Chris: Now that's a cool looking photo! Never thought of the Texan as a 'sexy' aircraft but that's just awesome.
Toshi: Great job there on the engines and mounts, I wouldn't want to cover them up either.
CMK02: I have no idea how accurate the yellow bombs are but they sure look cool.
Steve: I know what you mean about that nagging feeling of forgetting something but she looks perfect to me.
    June 2014
Posted by BrandonK on Thursday, May 11, 2017 9:09 AM
Bish
don't see many kits in black plastic.
Thank the Lord for that. The black is very hard to work with in regard to the seems. You can't see them at all and it's just not good color to work with when trying to make sure everything is right before paint. I would much rather have this kit in grey, it would be much easier to prep for paint.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    March 2015
Posted by Toshi on Thursday, May 11, 2017 10:43 AM
modelcrazy
Then if you want, add some ignition wires to them. That would really make them pop. Some small solder wire would work well.
Yes, I remember this pic during my Mustang build.  Difficult at best.  Definately worth the try.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    March 2015
Posted by Toshi on Thursday, May 11, 2017 10:50 AM
Gamera
Thank's Gamera.  Yes, I'll use the magnetic clear cowlings to show off the engines and mounts.
Toshi
    March 2015
Posted by Toshi on Thursday, May 11, 2017 4:20 PM
    March 2015
Posted by Toshi on Thursday, May 11, 2017 4:22 PM
    March 2015
Posted by Toshi on Thursday, May 11, 2017 4:55 PM
    March 2015
Posted by Toshi on Thursday, May 11, 2017 8:42 PM
    March 2015
Posted by Toshi on Thursday, May 11, 2017 8:44 PM
    March 2015
Posted by Toshi on Thursday, May 11, 2017 10:22 PM
    March 2015
Posted by Toshi on Thursday, May 11, 2017 10:24 PM
    March 2015
Posted by Toshi on Thursday, May 11, 2017 10:25 PM
    December 2003
Posted by scottrc on Friday, May 12, 2017 7:53 AM
What paint did you use to paint the inside of the narcells Toshi?
    November 2003
Posted by tempestjohnny on Friday, May 12, 2017 7:56 AM
Here is my contribution to the build. This kit looks beautiful.  I have a couple of the old Hasegawa kits in the stash which have now been put in the parts bin. No comparison.
    December 2003
Posted by scottrc on Friday, May 12, 2017 8:08 AM
I started assembly tonight.  Man, as I expected, I have a challenge and this kit cannot be built using the instructions. My RC plane building experience kicked in. For everything to fit, such as the engine, wings, cowl covers, and the cockpit fuse section, I am forced to jig up the airframe, and then start building the engine after the fuselage is secured and aligned and making adjustments to the engine by test fitting and sanding various assemblies so that the cowl covers and radiator will fit.  There also needs to be some support added to the inside of the fuselage when attaching it to the wing or else it will be out of alignment. When I am all done, there will still be a 1/16" gap between the wing root and the fuselage that will need to be filled, other than that, it was just a lot of trial and error, sanding and fitting to get everything to line up.  This is where I left off last night. Just tacked glued everything and will let it dry, if everything looks aligned, then I will glue everything up. Not a lot to show since it took a lot a concentration to focus on keeping everything in alignment.  The plastic if very soft and flexible.
    August 2015
Posted by crown r n7 on Friday, May 12, 2017 9:23 AM
Hi Bish can I add my gloster meteor to this build ?
 Nick.
    July 2014
Posted by modelcrazy on Friday, May 12, 2017 10:50 AM
Jack, not only did I forget the band I also forgot the leading edge yellow....Done.
I don't have pictures but, now I will add the decals. This may take a few days as I have other things on my plate for tis weekend. The next pictures should be with the weathering as well.
Steve
    May 2013
Posted by Greg on Friday, May 12, 2017 10:53 AM
Bossman
Scary - but very cool.
Chris
I have a hunch there is something about the physics of this little demo with the Texans which might make it less dangerous than it looks, but I did some dumb things in airplanes back in my younger days, and this would not have been one of them! Stick out tongue
Back to commenting on the last few pages of this GB shortly, just couln't resist this one realy quick. Geeked
    March 2015
Posted by Toshi on Friday, May 12, 2017 11:13 AM
scottrc
Model Master Enamel Chrome.
    March 2015
Posted by Toshi on Friday, May 12, 2017 11:16 AM
tempestjohnny
I'm looking forward to this build.
    March 2015
Posted by Toshi on Friday, May 12, 2017 11:19 AM
To scottrc,
It sounds like you've got everything under control.  Looking forward to the assembly of your build.
Toshi
Posted by Gamera on Friday, May 12, 2017 11:26 AM
Toshi: I agree, the insides of the nacelles there looks really good.
TJ: Ohhh, a Harrier- awesome!
Scott: Ouch, that looks like a pretty big weight you're being forced to use. Sucks when fit is that bad but looks like you've got 'er under control.
    April 2006
Posted by jgeratic on Friday, May 12, 2017 11:33 AM
Steve, I missed the yellow ID on the Spit`s leading edge as well.  Good idea to paint, I know some kits in the past provided that marking as a decal option.
Scott, looks like you have a kit that must be beat into submission.  I`ve got the Eduard release of the Se.5a, though it is 1/48 scale.  Are you doing the Hisso or Viper engine?
regards,
Jack
    December 2003
Posted by scottrc on Friday, May 12, 2017 11:49 AM
jgeratic
regards,
Jack
After building the Albartross, I expected this to be a "builders" build.  I do know that after this model is finished, I plan to treat myself to a Wingnut Wings kit.  I have seen a lot of fascinating things done with those kits.
I think I am doing the Hisso, its hard to tell if I'm using the correct parts since the instructions are so vague. Again, thank goodness for a number of great Youtube videos on this kit.  I now know why Squadron was giving these kits away for $10 at Eaglequest one year, they did not have English instructions and the pictures are very plain.
Hope to get to spend time on it this weekend.  I am sure there is going to some interesting developements as to how this assembly goes together.
    September 2003
Posted by checkmateking02 on Friday, May 12, 2017 12:25 PM
mc:  well done camo on the Spitfire; looking good!
Toshi:  magnificent detail work on those engines and all; exceptional
tempest:  what a great plane!  Looking forward to your build.  Years ago, Harriers appeared at the EAA airshow/fly-in at Oshkosh, Wisconsin.  It was amazing to see them take off and land.
scott:  what a challenging kit!  I tried Roden's Pfalz in 1/72 years ago; didn't do so well.  May the plastic submit to your will!
    March 2015
Posted by Toshi on Friday, May 12, 2017 2:45 PM
I've finally completed the assembly of the Nacelle.  Now it's time to assemble the other nacelle.
Toshi
    March 2015
Posted by Toshi on Friday, May 12, 2017 2:48 PM
    March 2015
Posted by Toshi on Friday, May 12, 2017 2:49 PM
    March 2015
Posted by Toshi on Friday, May 12, 2017 2:50 PM
    March 2015
Posted by Toshi on Friday, May 12, 2017 3:00 PM
Gamera
Thank you Gamera!
Toshi
