Frank, following Dave's tip- it is ALL his fault- I picked up a Hase S-92 today, yahoo!
I'm looking forward to opening it and scanning throught the decals and histo when she flies in.
Are you thinking about a CS-92? If so, I'll scan the decal sheet and send it to you, for info only of course, so that you can see if it's got a second set or such you could use.
![](http://i295.photobucket.com/albums/mm150/6134rdm/s-92-1.jpg)
Some Pilsner Urquell may be consumed in the commission of this act!
Guyster- have you seen this conversion kit? In California, you need a fifteen day waiting period before you can pick it up!
http://acc.kitreview.com/schatton4871reviewbg_1.htm
Sean- I do have to say that those big kits had a bad rap for shape issues, just bear in mind.And last, here's a preview of the Oprey guide, on Amazon, that has some useful if dated (2006) info.
http://books.google.com/books?id=8fR3tr-GiLEC&pg=PA5&lpg=PA5&dq=hasegawa+me+262+post+war&source=bl&ots=mBXgA1HapR&sig=b9CIVjIJmWkAeqRGQsIHrS2y1Dg&hl=en&ei=HgnESqHuHIngswOR1om3Cg&sa=X&oi=book_result&ct=result&resnum=6&ved=0CBsQ6AEwBQ#v=onepage&q=&f=false
Happy Trails!!!
