Way Too Many Props GB April 18, 2011 - Extended to July 28, 2012
    August 2009
Posted by TREYZX10R on Monday, April 16, 2012 4:45 PM
Doogs very clean looking primer job,excellent!
Len looking forward to seeing them
Bish If I got your question right the pedestal is the gunners position and the pole in front is the priscope sighting system
I'm plugging along with the sub assemblies and started filling seams,tedious work
Posted by Bish on Monday, April 16, 2012 4:55 PM
Right, i thought that looked like some sort of periscope. But i never thought of it being a remote gun station. To be honest, i wouldn't have thought it would have carried guns, seeing it more like a modern bomber, such as the B-2, than a WW2 bomber bristling with guns. But of course, that ignores aircraft like the B-52.
In fact that seat looks like a capt's chair with a periscope to give him a better view.
Its looking good. Would i be right in assuming its going to have an NMF.
    August 2009
Posted by TREYZX10R on Monday, April 16, 2012 5:11 PM
Bish
Bish thanks and totally agree the guns were a cary over and I'm geussing had it really went into service its likely they would've been deleted. The prototype just had the blisters sans guns, in fact the 'tail' gunner bubble is painted over so I wasted time building that station. Yes NMF is the order of the day on this one and frankly I'm a bit unnerved by so much surface area going that route!
    July 2007
Posted by troublemaker66 on Monday, April 16, 2012 5:33 PM
TREYZX10R
 Bish:
Fear not my friend...if anyone could do it, you can. That`s gonna be one bad a$$ looking flying wing...Yes
Len Pytlewski
Posted by Bish on Monday, April 16, 2012 6:10 PM
troublemaker66
 TREYZX10R:
 Bish:
Ditto I've seen your builds. I have every confidance. So no pressure.
    February 2011
Posted by Reasoned on Monday, April 16, 2012 9:28 PM
This is why I'm still stuck on this beast, what a PIA, never have I seen such difficult seams.  My first attempt at a Swanny seam trick, not sure it will work for me but here it goes.....
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    June 2010
Posted by DoogsATX on Monday, April 16, 2012 9:36 PM
At least it's a very straight seam?
Also, HOLY WING SPAR!
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    February 2011
Posted by Reasoned on Monday, April 16, 2012 9:44 PM
Yeah, if you saw the wing you'd know why.  I may end up taking this thing into a bodyshop to get the wings TIG welded on!
    July 2007
Posted by troublemaker66 on Tuesday, April 17, 2012 4:52 AM
Reasoned-
Could you explain or post a link to Swanny`s tip? When you say "uneven" do you mean one side of the fuse` is sticking up higher than the other where you glued it? That`s a looong seam and I`ve had the problems you described with a B-29 in the past.
Len
Len Pytlewski
    June 2010
Posted by DoogsATX on Tuesday, April 17, 2012 11:12 AM
Len - Swanny's tip is basically to "gate" the seam with tape close on either side, apply putty, smooth it out/down with acetone, then pull the tape up. This way you don't make a giant putty mess. Use it all the time myself and swear by it for fuselage seams.
Speaking of...went back with some Mr. Surfacer 500 last night and cleaned up a few areas. Reprimed them.
The white base goes down tonight. I'm planning to lay down white, then preshade, then lay down white again to make sure I get  the coverage I'm looking for.
Posted by Bish on Tuesday, April 17, 2012 11:17 AM
Doogs, thats looking good.
I have read that tip on Swannys site. Do you use neat acetone, i have read it can damage the plastic. Or do you use nail polish with acetone in it. I am haveing trouble finding the latter.
    July 2004
Posted by Lt. Zogg on Tuesday, April 17, 2012 11:34 AM
Doogs, that PV-1 is looking really nice.  Yes For some reason it makes me hungry for BBQ every time I see it though...Big Smile
Trey, that flying wing is really cool, is that a stock cockpit, or did you add AM details?  Yer gonna need a big shelf for that one!
I'm making very slow progress on the Lanc, been working for the last several weekends, so haven't had much time at all.   I've started filling/sanding some of the fuselage windows that were faired over on the real ones.  Been having a tough time figuring out which ones were covered on the later versions.
Jeff
    February 2011
Posted by Reasoned on Tuesday, April 17, 2012 12:18 PM
Bish
Doogs is correct in his description of the process, apparently you have it down pat Doogs, any pointers?
I used "Wally World" nail polish remover (I'm cheap).  I will say a couple of things having tried this 1) I am glad I went back out and bought the Squadron "white" putty, instead of trying this with the green stuff 2) As I have never used this type of putty before BOY does it dry FAST! 3) Because it dries so fast, going back over with the acetone on Q-tip gave me mixed results in that it didn't seem to smooth out the way I'd like (i.e., I had a TON of sanding to do, to get it smooth....er).  and 4) I was more messy than I should have been (see above photos) and got putty outside the gate, which had to be sanded.  Now I'm going to have to go back over the whole model, probably an inch on either side of the seam with 1000 grit sandpaper and wet sand to get all the flipp[ing scratches out! Bang Head
    June 2010
Posted by DoogsATX on Tuesday, April 17, 2012 12:28 PM
I wouldn't say I have it down pat, but I've got it down to a minimum of expletives.
First, I use 3M Acryl Red putty, thinned down with either nail polish acetone or with lacquer thinner. Depends on my mood. I mix it up to where it's more of a sloppy paste - a bit thicker than white glue - then slather that into the seam.
I also work in short lengths...I'll tape off the entire seam at maybe 3" intervals, so I only have to deal with that much at a time.
After the putty's had a minute or so to set up (enough that it can "grab"), I swipe it with either a q-tip damp with NPR acetone, or with a finger (in a glove, of course, that stuff's nasty). As soon as I  do a run to a break (say, cowl to canopy), I bust out the sanding tools to knock down the tape ridge. Then as it sets up even more I'll come back with fine and ultra-fine grits to really smooth the seam out.
    September 2009
Posted by B17Pilot on Tuesday, April 17, 2012 12:53 PM
That's pretty much how I do it too!  Key thing is to do small sections at a time.
    September 2009
Posted by B17Pilot on Tuesday, April 17, 2012 12:57 PM
Reasoned
Not to be a smart guy but in looking over the roster (25+ including multiple builds for some), the first page shows only 6 completed, is this correct (not having looked through all the pages)?  I know I committed w/B-36 (what an idiotEmbarrassed) and I promise to have some WIP and this finished before the 7/28/12 date........ (or I will quit this hobby......... which is still possibleWink).
Life gets in the way, I reckon!  Or in my case, my second one, the Ventura, didn't even hit the market till earlier this year.
    February 2011
Posted by Reasoned on Tuesday, April 17, 2012 1:18 PM
DoogsATX
Idea Great idea on the paste, I half thought about that and it would make it much easier to work with.
Well, 3" sections are just fine on a 1/48 109 or P-47, on a 1/72 B-36 that's about 2 weeks of work! Stick out tongue  Just kidding, that seems like about what I was trying to work with but again, that stuff dries really quick.
    July 2007
Posted by troublemaker66 on Tuesday, April 17, 2012 4:17 PM
DoogsATX
Really?  I`ve been doing the same thing for years..except I didn`t use acetone. Thought I had a good idea...oh well. It`s funny because I used putty without masking all the time but would get it in places I didn`t want to so I had the great idea of masking both sides of the seam...I seem to be a day late and a dollar short, once again..lol.
Lately, I`ve been doing my seams with CA and accelerator...no mess and you don`t have to wait for putty to dry...Wink
Len
Len Pytlewski
    August 2009
Posted by TREYZX10R on Tuesday, April 17, 2012 7:09 PM
Jeff thanks,its all oob stock. Looking forward to seeing the Lanc progress.
Doogs looking good,I like that method for filling seams as well and will be using it a lot on this wing the joins on the leading edges are terrible!
I opened up the leading edges and hollowed the wing ,more tedious filling ahead!
    February 2007
Posted by T-rex on Tuesday, April 17, 2012 9:48 PM
Wow now thats a big flying wing, nice work!
Good thing you extende he GB I haven't work on my FW 189 yet, but I am one with my OT-26, so I should work on it now.
Working on: Trumpeter SU-152 (1/35) Trumpeter E-10 (1/35) Heller Somua (1/35)
"The world is your enemy, prince of a thousand enemy. And when they'll find you, they will kill you... but they will have to catch you first ''
    June 2010
Posted by DoogsATX on Wednesday, April 18, 2012 11:03 AM
And the painting begins! Got the undersides covered in Gunze Offwhite last night. Hands down my favorite white paint.
Now that I've got a good base, I'll be shading and overcoating tonight. Then it'll be on to the blues.
    January 2003
Posted by p38jl on Wednesday, April 18, 2012 12:23 PM
Doogs and Trey.. looking sweet !!
[Photobucket]
    September 2009
Posted by B17Pilot on Wednesday, April 18, 2012 12:32 PM
Doogs - Man you've gotten ahead of me on the Ventura!  I've been side tracked with other non modeling projects and a getting a P-47 done for the NMF GB.  Need to return to putty my Ventura
Trey - Dude those hollowed out parts look sweet!
    March 2010
Posted by Hercmech on Wednesday, April 18, 2012 12:51 PM
DoogsATX
http://i780.photobucket.com/albums/yy86/doogsatx/Aircraft/Revell%20PV-1%20Ventura/b9108d3f.jpg
And I thought I had a lot of paint!!  Looking great btw
13151015
Posted by VanceCrozier on Wednesday, April 18, 2012 1:09 PM
Hercmech
 DoogsATX:
He needs a pile of paint, building in 1/32 most of the time...
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    June 2010
Posted by DoogsATX on Wednesday, April 18, 2012 1:55 PM
VanceCrozier
 Hercmech:
 DoogsATX:
That's just the Tamiya and Gunze...
    March 2010
Posted by Hercmech on Wednesday, April 18, 2012 2:58 PM
Oh My!
13151015
    June 2010
Posted by DoogsATX on Thursday, April 19, 2012 8:08 AM
Alright...so painting white is easy. Painting a worn white not quite as easy.
Over the offwhite base, I switched to a mix of Middlestone and Olive Drab for panel lines and panel shading. Thinned Neutral Gray was also streaked in the direction of airflow.
Thinned the offwhite way down and went over it all, stopping just where I think the effect is still too noticeable. It's been my experience that once more pass would look great, but disappear under clear coats, washes, and weathering. So I'm trying leaving it a bit more blatant this time out.
Posted by VanceCrozier on Thursday, April 19, 2012 8:42 AM
DoogsATX
 VanceCrozier:
 Hercmech:
 DoogsATX:
http://i780.photobucket.com/albums/yy86/doogsatx/Bench%20MkII/file-9.jpg
He's a paint-pimp...
    March 2010
Posted by Hercmech on Thursday, April 19, 2012 9:37 AM
DoogsATX
http://i780.photobucket.com/albums/yy86/doogsatx/Aircraft/Revell%20PV-1%20Ventura/04cf7e44.jpg
http://i780.photobucket.com/albums/yy86/doogsatx/Aircraft/Revell%20PV-1%20Ventura/0dd52fbe.jpg
Very well executed!!! I like the look that puke yellow gave the white. Much better than blcak or a dark gray would have done.
13151015
