Way Too Many Props GB April 18, 2011 - Extended to July 28, 2012
    June 2010
Posted by DoogsATX on Wednesday, March 28, 2012 10:16 AM
So instead of the Testors stuff I picked up a bottle of Micro Krystal Klear, which does the same things. The PV-1 windows are bigger than the max 1/4" stated, but a piece of acetate on the inside provided a nice support.
Things aren't done curing, but here's the window.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    January 2003
Posted by p38jl on Wednesday, March 28, 2012 10:30 AM
It should look good when totally dry Doogs.. I've done that trick before..
[Photobucket]
    July 2007
Posted by troublemaker66 on Wednesday, March 28, 2012 11:03 AM
[quote user="DoogsATX"]
http://i780.photobucket.com/albums/yy86/doogsatx/Aircraft/Revell%20PV-1%20Ventura/a8d4ed77.jpg
Did you try without the acetate 1st? I`ve been able to stretch the film over some nice sized openings. Like I said, I used acetate to back the Betty`s bomb window,which.come to think of it, haven`t checked to see how it came out...just did and it`s a bit cloudier than if it was without acetate. Yours looks pretty good..may have to do one more coat to get it flush. Sometimes it takes forever for it to dry, especially if you go heavy. Looks like you went light..best way. I love this stuff!
Len
Len Pytlewski
    August 2009
Posted by Sparrowhyperion on Wednesday, March 28, 2012 11:16 AM
I usually use a tiny piece of Saran Wrap (cling food wrap).  I stretch it almost to the breaking point on the inside of the window frame, then make sure it is well secure, then I use Micro Crystal Clear on the outside of the window to build up two to three layers.   If you do it right, afterwards you just trim the saran wrap around the window frame and leave it for the extra support.  Using it lets you build up some very large windows if you have to.
Rich
[quote user="troublemaker66"]
DoogsATX
Len
In the Hangar: 1/48 Hobby Boss F/A-18D RAAF Hornet,
On the Tarmac:  F4U-1D RNZAF Corsair 1/48 Scale.
    June 2010
Posted by DoogsATX on Wednesday, March 28, 2012 11:19 AM
troublemaker66
Len
I did try it without first, and it kept retreating to the edges. A window half the size probably wouldn't have been an issue. Think you're right about another coat to get it flush with the surface...I'll see how it's coming along tonight.
I'm also totally planning to start using this stuff for instrument dials. One problem I've had glossing the dial faces is that all the glosses are very self-leveling, and raised-detail or color PE panels have enough texture that they mess up that uniform smoothness. A dot of this stuff, maybe thinned slightly with water, would give that nice flat surface.
    September 2009
Posted by B17Pilot on Tuesday, April 3, 2012 10:47 PM
Engines painted!  Instructions called for a light grey crankshaft, but in black and white period photos I have, the crankshafts looked darker, so went with that. They still need a wash, but here they are! Next, fill seams and such before paint
Close up of one:
    June 2010
Posted by DoogsATX on Sunday, April 8, 2012 3:09 AM
B-17 - digging the engines! Got mine painted up, too, but not weathered yet. I've been a bit distracted by the George over the past few days as it's worked its way through the paint shop. That and I'm still waiting on the single-piece bomb bay from D-Molds and I'm investigating a custom mask for the octopus arms, so I haven't been rushing.
That said, I do have two small things to show PV-1 related.
First up...the super-sweet Ultracast wheels. Huge improvement over one of the few letdowns of the kit, especially in the tread department.
Next, the part I've been dreading more than any other...masking this ***. All the rounded corners on the windows. Ugh. Well, I read a tip somewhere a few days back about making small tape discs with a punch and using those to mask the curvy corners. Very fiddly to work with, but man, they work perfectly.
Posted by Bish on Sunday, April 8, 2012 3:26 AM
Damn, i lost track with this GB. Some very nice completed builds on the front page.
Interesting idea on masking those corners. I often have trouble getting the scapel around those curves to do them properly. As fiddily as this maybe, it may well be worth a go.
    September 2009
Posted by B17Pilot on Sunday, April 8, 2012 10:44 PM
Thanks, Doogs!  I've been distracted myself trying to finish up a P-47 for the NMFIII build.  Haven't done much on the PV-1 since the engines.  Nice idea on the canopy!
    August 2009
Posted by TREYZX10R on Tuesday, April 10, 2012 3:31 PM
Doogs,not envying you on the mask job,looks like you've got it well in hand tho!
B17Pilot great looking engines and the color choice looks spot on to me.
Would like to add a 1/48 Northrop XB-35 if thats cool? 32 Prop blades on this unit ;)!
    June 2010
Posted by DoogsATX on Tuesday, April 10, 2012 5:01 PM
TREYZX10R
This one's not so bad. Apart from the curvy corners everything's flat, and not too many acute angles to battle, either. Even on the aft belly windows. Curved corners, bit straight sides. Now I just need a night when my eyes aren't dead tired!
    September 2009
Posted by B17Pilot on Tuesday, April 10, 2012 10:03 PM
TREYZX10R
1/48! WOW that's going to be big!  What's the kit make?  I'll add it to the list.
    January 2003
Posted by p38jl on Wednesday, April 11, 2012 8:23 AM
B17Pilot
 TREYZX10R:
should be an AMT kit.. if I ever get my rearend in gear ,, I'm supposed tobe doing the same kit.. lolWhistling
[Photobucket]
    August 2009
Posted by TREYZX10R on Wednesday, April 11, 2012 3:35 PM
B17Pilot,sorry my mistake its 1/72 scale . P38 is correct its the AMT/Ertle. Yea 1/48 would be huge!!!! Its taxing my work bench at this size lol.
dry fit looks good
getting the office started(not that you'll see much of it when its done)
    September 2009
Posted by B17Pilot on Wednesday, April 11, 2012 8:29 PM
That sounds about right.  Didn't think there was a 1/48 kit of it.  Got the front page updated!
    August 2009
Posted by TREYZX10R on Friday, April 13, 2012 2:41 PM
Thanks B17Pilot! I got the office done. I remember now why I quit doing 72nd scale
Posted by VanceCrozier on Friday, April 13, 2012 3:08 PM
TREYZX10R
http://img.photobucket.com/albums/v710/treyzx10r/X-planes/xb-35-1004.jpg
That could be the bridge of a Federation Starship...
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    January 2003
Posted by p38jl on Friday, April 13, 2012 3:12 PM
VanceCrozier
 TREYZX10R:
  ditto!! Very nice ! Toast
[Photobucket]
    March 2010
Posted by Hercmech on Friday, April 13, 2012 3:22 PM
Trey: That cockpit is crazy looking. Awesome but crazy
Doogs: That window is looking good. I have that kit and just picked up the True Detail cockpit set...almost as much as the kit LOL and when I opened the kit I found the kit detail is almost as good. Sad What do you mean by the paint window then mask are?
13151015
    March 2010
Posted by macattack80 on Friday, April 13, 2012 5:51 PM
Nice work going on here guys!  Sorry I haven't had any progress on the Hawkeye.   My usual model building time is after work at about 1 am.  But lately I have been really tired and unmotivated..  I hope to get the ball rolling here soon.
Kevin
    July 2007
Posted by troublemaker66 on Friday, April 13, 2012 7:42 PM
Hey All,
I`m still pluggin` away at my two kits. Painted the Mosquito and gave the topside 2 coats of Future. I masked a little spot on the bottom and wound up ripping a giant piece of paint off with the tape....Bang Head Forgot I sprayed the fuse with aluminum metalizer and the white didn`t stick so good. If this was any other aircraft without a wooden fuse, that could`ve been a good thing weathering-wise....
...shiny...
I`ll post a pic of my little faux pas with the underside after the Future dries. I already sprayed over the spot but I think I`ll have to sand it down a bit to blend in the fix. Gonna decal her up once all is dry...more pix soon. Thanks for looking! comments / critiques are welcome.
Len
Len Pytlewski
Posted by Bish on Saturday, April 14, 2012 2:15 AM
Lovely pit Trey, shows what can be done in the true scale.
And Vance is right, it does look a bit like the bridge of a starship.Do you have any idea what the position of the pedastal is.
Trouble, nice paint job on the Mossie.
    June 2010
Posted by DoogsATX on Saturday, April 14, 2012 4:52 PM
Hercmech
Yeah the TD cockpit set was announced literally the day after I closed the fuselage! But overall I'm actually rather "meh" on True Details stuff. It's an improvement on the very old kits, but I don't think it holds up well against modern molds (or competition - the Vector prop set is worlds better).
As far as the window...I've already laid down the intermediate blue, and am going to mask close to the windows, then prime and paint.
Speaking of...the last big hurdle before primer has been taken care of:
I also checked my mail today and found the D-Mold bomb door waiting for me! It's like just-in-time manufacturing! Going to leave it off until close to the end so I can get in to put in the astrodome and ensure the wings go in right, but it'll be nice to ensure fit and get it primed along with everything else.
    August 2009
Posted by TREYZX10R on Saturday, April 14, 2012 10:43 PM
Len  looks like it will be okay,the finish looks tight and a little repair just lends some authenticity!
Doogs the mask looks great,looking forward to seeing some paint go down
Drilled out the exhaust ports and I'm ready to join up the wings on the beast
Thanks for all the support and kind words and totally agree with the Star trek reference the office is screaming beam me up Scotty!!!
    June 2010
Posted by DoogsATX on Sunday, April 15, 2012 11:10 AM
Trey - the wing's coming together fast! Shame to see "the bridge" all covered up.
Got some solid work in on the PV-1 last night. Note to anyone building it, the DMold bay doors have a corrected chin piece that also has to be installed by cutting up the kit. Yeah no.
That fiasco stole more time than I'd figured, so I only got to spray the interior green for the greenhouse and inside the cowls. Primer tonight unless it's downpouring.
    June 2010
Posted by DoogsATX on Monday, April 16, 2012 10:14 AM
Primer is down. Still have some areas I need to hit with putty and/or Mr Surfacer...that nose join in particular is a lot more prominent than it looks without paint, and there's a bit of work to be done on the fuselage and wing seams.
Also got word that the paint mask for the octopus should be shipping out in the next few days. Since it's coming from the UK, it'll probably take 7-10 days, so no rush for me to get the rest of the painting done at light speed or anything.
    April 2010
Posted by Theuns on Monday, April 16, 2012 12:47 PM
Hi all, I have lost interest in my ill-fltting and problematic Italeri Lockheed Hudson and was allowed to change to something with a better chance of completion.
I will be doing a 1/72 Italeri (hope this one is better!) C-47 Dakota in S.A. Air Force colours.
Pix to follow.
Theuns
    February 2011
Posted by Reasoned on Monday, April 16, 2012 1:52 PM
Not to be a smart guy but in looking over the roster (25+ including multiple builds for some), the first page shows only 6 completed, is this correct (not having looked through all the pages)?  I know I committed w/B-36 (what an idiotEmbarrassed) and I promise to have some WIP and this finished before the 7/28/12 date........ (or I will quit this hobby......... which is still possibleWink).
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    June 2010
Posted by DoogsATX on Monday, April 16, 2012 2:19 PM
Reasoned
Just six, really? Yikes...and just as I'm getting on a big bomber kick. PV-1. B-25's up next. Just picked up Revell's Ju 88A-1 and Monogram's B-24J (oh and god how I LOVE that the reissue is in Monogram packaging!). And a 1/48 Black Cat PBY.
Too many builds, and too many other responsibilities...
    July 2007
Posted by troublemaker66 on Monday, April 16, 2012 3:54 PM
Reasoned
There`s gonna be 8 pretty soon...my 2 are in the home stretch....Wink
Len Pytlewski
