Wow Razor, good work, nice builds, two even!
The Helldiver should be interesting. I'm guessing that's not the PE special edition? Interesting scheme on the Sabre, looking forward to seeing how it turns out. An older Airfix kit can be a good choice, being simpler, or a bad choice, if you need a pint of filler! Still, the Hunter is such a beautiful aircraft, and still in front line service today (Lebanon). Good luck with the Macross, don't know much about it.
Good progress Konig!
So far Owl, the fit is reasonable. Not used any glue yet. The larboard tail plane has a slight gap, but, I can live with that. The underside isn't a perfect join, but I'm not going to fill and scribe it.
In one hour, I sprayed the cockpit, joined the bits, sprayed the underside, and cleaned it up a bit. The rear of the underside was rough, needed some sanding, whilst someone in China left a great lump of sprue gate on the cowling, which needed to be removed.
After that, and a 6 hour break, I sprayed the props yellow, and have dipped the clear parts in Future/Klear. Not sure yet how to mask the underside windows, due to their tiny shapes. Maybe Micromask?
![](http://i1135.photobucket.com/albums/m627/Centhot/MadWeekendWildcata3.jpg)
![](http://i1135.photobucket.com/albums/m627/Centhot/MadWeekendWildcata4.jpg)
