Looking good gang - I'm grabbing some free wifi access while waiting to pick up my daughter, I'll have to go back & catch the pages I've skipped over, see what I've missed.
Needbeer - I don't usually go for "pointy silver things", but those red+white stripes look awesome on that bird.
Dupes, I see you are being monitored as well, making sure you don't extend past the weekend - I've got one checking up on me as well...
The box & decals - a quick test from the RAF sheet & I think I'll be able to used the OOB decals for the Swiss machine.
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1709sm.jpg)
The plastic is black. And very hard, it's almost like working with black ABS plumbing pipe. Takes FOREVER to sand down, and as I found out later, takes forever for Tamiya cement to settle down. I woke up this morning to find one of the drop-tank pylons had dropped enough you could see through the gap it left behind! I assume this type of plastic was chosen for two reasons: no painting needed for the kiddies that wanted it to look like the 111 Squadron birds on the front; Hard as nails so said kiddies could chase their sister around the house without fear of breaking the plane!
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1708sm.jpg)
(Somebody asked me "how old" - my boxing is only one year younger than I am!
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1752sm.jpg)
Wing halves together...
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1712sm.jpg)
Yep, this is the sidewall detail! ![Big Smile](/emoticons/emotion-2.gif)
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1713sm.jpg)
The ejection seat, I'll set that aside for some other project...
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1714sm.jpg)
Fuselage halves together...
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1715sm.jpg)
Well the good news - the ailerons are actually separate pieces, so I'll deflect them a little. Bad news, uhh, one is obviously thicker that the other! And a slight gap at the wing/fuselage joint, and several dimples on the fuselage where the locating pins are.
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1747sm.jpg)
Oh yeah, the underside. Remember how I said I'd be going gear-up on this? Well, I forgot!
Should have blanked off those areas before closing up the wings etc. Sooooooo I put the wheels to work, giving me something for those little black slabs to rest on as the glue set up! I added some sprue scraps to the nose from the cockpit opening.
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1748sm.jpg)
Putty? What putty?!....
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1753sm.jpg)
OK, there is a fair amount of putty! As tempting as it was to hang 8 stacks of rockets on this thing, I couldn't find a pic of a Swiss Hunter with rocket rails, so that accounts for the putty dots on the outer wings.
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1754sm.jpg)
Krylon flat white primer - not sure I'm convinced it'll be my new primer, it lays on really thick. No harm on this kit.
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1755sm.jpg)
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1756sm.jpg)
The official time judge checking in on my progress...
![](http://i1012.photobucket.com/albums/af250/VanceCrozier/Hawker%20Hunter/IMG_1757sm.jpg)
I actually have the underside light gray on as of an hour ago. Using Tamiya acrylics (over the Krylon - crossing my fingers!) so I should have no problems adding the topside gray & green this afternoon/evening.
