Striker8241
Hey Guys,
Here is a preliminary look at the bomb bay doors configured in load position. The detail on the door is only suggestive, not authentic. The only bomb bay detail I'm adding is the catwalk structure along the sides, since that's about all you will be able to see with the plane sitting on the ground
Russ
Russ;
I thought you were new to model building, but do correct me on that.
I can see how you know the subject and are handy with the materials. You didn't start yesterday, right....lol
When i checked my BUFF I realized I have just enough tolerance left over to cut the upper doors as you have described....I saw them, but never translated that info to the kit, lucky for me you pointed that out. You must have cut about 30 or so little ribs to finish the uppermost section of the belly doors? and re-cut the top hinges?
Russ, where did you get the catwalks, I'm guessing sheet stock, patience, and a drill?
Nice work on the bomb belly and bulkheads, You lined the inside of the lower doors with thin stock sheet right? And How come?
Thanks for explaining the Radome, I guess the Revel and Mono kits are exactly the same tooling after all....What with you in addition to this thread, we are turning into a scratch channel.....
Also, did you put in some scratch just behind the bomb belly, over the rear wheels.....your build is really shaping up man.....I hope you don't mind if I take some of your ideas....
Dom
