Wow! Sometimes I can be away from this GB for a few days and only miss a couple posts. This time, I'm out for a few and, oh boy ....... lotta stuff happenin. Hope everybody had a great 4th (well, fellow Americans anyway). I didn't do too much, grilled some burgers, enjoyed the weather which has been great for a number of days now. unreal.
JOE, Eric, Clemens: Nice work on your birds. I love to see what you truly talented guys are up to. It's a little intimidating yet, inspiring.
I've dabbled a little with Silly Putty myself and found it a pain. It's very fussy about temperature. Narrow temp range where you can work it properly. I find it handy for stuffing holes though. It's too bad there isn't some magical potion to make Silly Putty rock hard instantly. Imagine the uses as a gap and contour filler.
To answer the question about my battle damaged canopy: First of all, the canopy had been dipped in Pledge Future, which may or may not have helped but worth mentioning. I started the hole by slowly pressing and twisting a scribe tool in the plastic, keeping a finger inside to support it. Once I had a decent divot, I used a fine round needle-point file, very handy tool, and carefully turned that, using very little pressure and with my finger still inside, until the file came through. At which point, the file was wanting to grab too much plastic, so I switched to a very sharp blade, turning it until I had my desired hole size. Now, with the very sharp blade point, I very carefully carved randomly spaced deep scratches radiating outward from the hole (it's important to do this in one non-stop stroke for each line). Some I branched out, some not, but virtually none are straight. I finished by adding some connecting lines between the radials, forming a screwed-up circle around the center. It ends up looking like the glass is broken into chunks, but it's only scratched. And yes, the pilot was fine. The bullet entered just behind the armored headrest so this wasn't the kill shot.
Bill.
On the bench: Lindberg 1/32 scale 1934 Ford Coupe and a few rescue projects.
In queue: Tamiya 1/35 Quad Tractor or a scratch build project.
