Gift GB
    December 2012
Posted by Z Square 8 on Wednesday, March 20, 2013 12:31 PM
I broke out the sanding screen last night and went to work. I analyzed the impact and decided that I would sand and polish the wing smooth since so much of the impact area was so close to the lines and even on them. I will then address the loss of the panel lines. I have an idea for the repair of them in lieu of sprue stretching (I tested my skill with that and found I could not meet my own expectations), I will test this avenue after I see the true impact to to the panel lines after I re-prime the area this afternoon.
--Rich
Site builder of CooksonTributeB29.com
    September 2003
Posted by checkmateking02 on Wednesday, March 20, 2013 1:08 PM
Go for it, Rich, and good luck!
Posted by Bish on Wednesday, March 20, 2013 3:49 PM
Sounds like you got your work cut out Rich, but sure you can pull it off.
    October 2008
Posted by eatthis on Wednesday, March 20, 2013 4:12 PM
you cant get the paint off/down without sanding it?
whenever a spray gloss in the wirbrush or a rattlecan it ALWAYS looks like that apart from halfords own appliance white strangely
snow + 4wd + escessive hp = :)  http://www.youtube.com/watch?v=x7egUIS70YM
    December 2012
Posted by Z Square 8 on Thursday, March 21, 2013 10:55 AM
The wing repair is progressing...not finished yet by no means:
Did some decal scaling work with older renditions and tested...
--Rich
    September 2003
Posted by checkmateking02 on Thursday, March 21, 2013 11:45 PM
It appears you're getting the problem solved, Rich.  And the decals are looking good.  Nice progress.
    October 2008
Posted by eatthis on Friday, March 22, 2013 2:59 AM
done :)
alclad chrome is ace!!
armerment
3x30mm aden cannons under the nose intake
2 early ir homing missiles (pilots didnt rate them at all)
2 external fuel tanks
from early war to late war
Posted by Bish on Friday, March 22, 2013 3:28 AM
Nice, sounds like this thing packs a big punch. Thanks for bringing this to the GB.
    April 2011
Posted by badlanguage on Friday, March 22, 2013 8:14 AM
Eatthis, that chrome looks fantastic! Great build, thanks for sharing. And Z, can't wait to see how the wing turns out.
I've been looking for tips on how to paint metal finishes better, and so far I've learned a lot by tuning in here. Thanks to all!
    September 2003
Posted by checkmateking02 on Friday, March 22, 2013 9:42 AM
That looks slick, eatthis.  Really great looking NMF.  Good work!
    April 2011
Posted by badlanguage on Friday, March 22, 2013 10:18 AM
Trying to make the decals I want for my Gundam. I found some 1/100 scale decals for the version I'm building, but I need them in 1/144 scale. I scanned in the decals, plucked out the ones I wanted, cleaned up the images and removed the background blue of the decal paper, and created images of them. Fortunately for me I only needed to get the bigger ones, since I have a very detailed decal sheet in 1/144 scale from another version of the Gundam (which I'll borrow heavily from). I have some resizing of the images to do - the big white image will probably be at most 1.25 inches wide. I put the images on a blue background so I could see the white ones, obviously that won't be there when I print on decal paper. Anyway, here they are.
    December 2012
Posted by Z Square 8 on Sunday, March 24, 2013 4:08 PM
BL- will be interested to see the final decal work...you are making great progress.
eatthis- love the clad enthusiasm...great results! Yes
29 Build update: The repair of the right wing paint tabacle is complete. After sanding, I took a piece of landscape wiring and stripped it to reveal stranded wire. Then I took a single strand and pulled it through a small puddle of clear parts glue and touched each panel line and removed the wire. It left a small ridge of glue to simulate the raised panel line...not perfect, but may just be enough. I proceeded with a few touch ups to sanding and polishing...and then on to masking...she is ready for cladding. After that is done, I will revisit some additional panel work as necessary.
Some WIP below: (including engine/prop assemblies)
Masked bottom side-
The assemblies close to their homes...tempting huh?
Smelling the build assembly finish...undetermined yet on washes. Decaling and detail work pending.
--Rich
    December 2012
Posted by Z Square 8 on Sunday, March 24, 2013 4:14 PM
Just for fun...I tested the metal plate buffing over a spare part that had been painted and dipped in Future and was completely dry...when attempting to buff, it appears that the metal buffing spray ate through the future and softened the original paint. so when trying to buff to a polish shine, it removed all back to the bare plastic or grey primer. FYI...
--Rich
Posted by Bish on Sunday, March 24, 2013 5:52 PM
Interesting dcals bad, i still haven't come close to makeing my own, looking forward to seeing how this work out.
Z, glad to hear you have the problem sorted. I think i washed my NMF's with my usual pro modeller and then used Tamiya's weathering pastels, the gun metal, on it. But its been a while now and not entirely sure. The 29 is looking good.
I've made a start on my 0/400. Last week was a bit slow and still not got the inside done, even though tehres not much there. But should have some pics in a day or so and hopeing to pick up the pace this week.
    September 2003
Posted by checkmateking02 on Monday, March 25, 2013 6:38 PM
Sorry to hear about the set-back, Z.  What did work for the NMF looks really good.
I haven't done a NMF in years, but when I did, I used Floquil RR paint.  They make about three different labels of silverish color--although my can't really see the difference.
I find NMF's to be. . . anxiety-provoking.
    April 2011
Posted by badlanguage on Saturday, March 30, 2013 5:16 PM
Making more progress on the Gundam. I thought I took more pics of my work in progress, especially some of the little pieces that I painted, but I'm putting up what I got.
Base coat of the beam saber. That's kind of like a lightsaber for giant robots.
Shiny brass band on the back of the legs. I saw it on another one and I liked the color contrast, so here it is.
Beam saber with some pink on it. I have no idea how to paint a piece of plastic to look like a lightsaber, so I'm winging it.
More beam saber.
Here are the bits and pieces ready for clear. With the exception of the hands and the rest of the weapons this is pretty much the whole thing. I'm going to clear and decal and then get to the weathering. Sometimes I put these models together before I weather and sometimes not. I think this time I'll weather before I put it together. Making decals now, I'll post pics when I get them done.
    May 2005
Posted by pyrman64 on Saturday, March 30, 2013 5:59 PM
I've never said this to a guy before, but...nice GAMS!! Whistling
You might try using Future and Tamiya clear paints for the light saber thing.  Looks great.
Greg H
"There is many a boy here today who looks on war as all glory, but, boys, it is all hell." Gen. Wm T. Sherman (11 April 1880, Columbus, Ohio)
    April 2011
Posted by badlanguage on Saturday, March 30, 2013 9:35 PM
I just realized I never posted a pic of the bits and pieces! Anyway, here it is.
    April 2011
Posted by badlanguage on Sunday, March 31, 2013 12:33 PM
Good tip about the Tamiya clears, for some reason I keep forgetting they exist! Maybe I'll pick up a bottle and experiment a bit...
Posted by Bish on Sunday, March 31, 2013 1:27 PM
Nice work there bad. Those tamiya clears do come in very handy. I have all the clear colours and often forget about them.
    April 2011
Posted by badlanguage on Sunday, March 31, 2013 1:40 PM
Yeah, I can think of a couple spots on this model alone where the effect I was looking for would probably have been achieved better by a silver/chrome base with a clear color on top. I definitely need to start working with them so I remember they're there!
    September 2003
Posted by checkmateking02 on Sunday, March 31, 2013 6:38 PM
Nice-looking parts, BL.  Should build up fine!
Are these Tamiya clear colors acrylic or enamel/lacquer?  I haven't used them or even looked at them.  Maybe they'd be useful.
    December 2012
Posted by Z Square 8 on Sunday, March 31, 2013 6:46 PM
That mech is going to be "pretty trick"...anxious to see the continued progress!
Happy Easter to all...
29 build update...the cladding of the 29 is complete.  She received 3 shades of clad including: airframe aluminum, dull aluminum, magnesium and also took on some silver plate buffing metalizer, (which I really liked the control of even though it meant extra work!)
Wing tabacle abated...but I'll let you folks be the judge on that! LOL...the shortcomings of the overall result is in the base coat and sanding (surface prep before clad). I would definitely do some things different now, but feel I made a "fair" recovery. Intrigued to see??
...doing some touch ups this evening and should get images up by Tuesday/Wed.
--Rich
    December 2012
Posted by Z Square 8 on Monday, April 1, 2013 9:17 AM
Here we go...
Wing before:
Wing after:
Her cladding:
I think the first image of cladding (after the wing before and after shots), is the best of the cladding as it shows more of the true shading because of lighting adjustments.
I failed to get an underside shot, but it looks slightly better than these because of limited surface work I had to do on it. You'll get a chance to see that after the assemblies have been secured in place.
Thanks for looking.
--Rich
    September 2003
Posted by checkmateking02 on Monday, April 1, 2013 9:38 AM
Vast improvement.  Great recovery!
    April 2011
Posted by badlanguage on Monday, April 1, 2013 9:46 AM
checkmateking02
I believe the Tamiya clears are acrylic (the rest of their colors are). Z, nice looking 29! I really love the effect different metals have when applied that way!
Question for you (and anyone else who may know) - how do Alclad metals compare with Testors metalizer as far as how to use them and how they look? I have a project in mind that I'd like to use a NMF on and I could use the advice.
    December 2012
Posted by Z Square 8 on Monday, April 1, 2013 9:52 AM
BL- I have limited experience with both, but used both on the 29. Suface prep is the key to alcald!
the metalizer I really like because in an hour you can buff it to whatever degree of "shiney" you want. I used it on the cowlings. If you peruse back to those images you can see I went to a high shine on the front edge and left a section more dull and then went back to shiney.
--Rich
Posted by Bish on Monday, April 1, 2013 12:06 PM
checkmateking02
They are Acrylics. X-23=Blue. X-24=yellow. X-25=Green. X-26=Orange and X-27=Red. I don't think i have hardly used the blue yellow or orange. But the green and red come in very handy for wing tip lights.
Posted by Bish on Monday, April 1, 2013 12:07 PM
Z, thats looking really nice.
    September 2003
Posted by checkmateking02 on Monday, April 1, 2013 12:12 PM
Wingtip lights were what I was thinking, Bish.
Do you paint them silver, then apply the clear colo(u)r?
