Artillery Group Build
    April 2006
Posted by waynec on Saturday, May 16, 2015 5:26 PM
i have never primed with black. going to have to give it a burl.  working on more elevation mechanism parts. trying to be time efficient but still doing a lot of filling just in case.i think i will paint the entire interior PANZER GRAY even though the outside is DARK YELLOW.  it's strange having parts bigger than what is shown in the instructions.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    April 2006
Posted by waynec on Saturday, May 16, 2015 5:29 PM
Gamera
Wow, that is awesome Wayne- what would be even cooler if the big gun fired velociraptors like a human cannonball! Bad guys are sitting in a room and suddenly BAM! an angry raptor crashes though the ceiling!!!
it looks like it chambers out at the muzzle to .25cal and i have friends telling me i could make it fire..
    January 2013
Posted by jibber on Sunday, May 17, 2015 6:48 AM
Wayne you probably know I prime in black almost all the time, and I use Army Painter primers.  Its sold by mostly gaming companies but I won't use anything else. It dries in minutes, goes on perfectly out of a can and the finish is even and smooth. Thats what I look for in a primer, besides it fills in all those little nooks that you may miss while spraying. There is some overspray of a fine dust so I do it outside when possible. Try a can, they make a lot of colors and you'll be hooked.
A 24" inch barrel…..I never would have thought that in modeling, now thats going to be a real showpiece.
    April 2006
Posted by waynec on Sunday, May 17, 2015 3:50 PM
my ACE HARDWARE NOW gray and no doubt the black primer does that too. i have a special cardboard box just for that when i spray inside but also tend to use the garage.
INRE last post, i did clean off a station and pulled out DD that has to be done by mid June. looks better than i thought given it will be cased on a shelf so not going to have contest scrutiny. no excuse for building poorly but it does mean some little boggers won't be seen.
got 12 powder bags painted gray white and 12 canisters german gray. when they dry will paint black rounds and brass end casings. (ran out of clips). also painted ammo cart german gray instead of yellow for some contrast. here is the elevation mechanism set together. going to be a lot of individual priming and painting. ig it looks a little rough remember 1. i will clean it up some more, 2. all of this inside the carriage won't be seen, especially down in travel mode and 3. i'm assuming they would leave the inside gray to conserve paint. pity as this is a pin wash dream.
ON A SIDE NOTE. vallejo paints nicely but i find, even after cleaning, if i let the airbrush sit for a couple of days it gets stiff. had to field strip mine today. easy enough to run anything like water though it each day to prevent that.
    July 2014
Posted by modelcrazy on Monday, May 18, 2015 11:56 AM
Wow, looks outstanding Wayne.
Steve
Posted by Gamera on Monday, May 18, 2015 8:12 PM
Gee friggin' whiz Wayne, that thing is huge!!! Very nice work there so far too.
    January 2014
Posted by Rob S. on Monday, May 18, 2015 8:17 PM
Looks great Wayne...interesting that you point out the Vallejo comment WRT your airbrush...I too notice that exact same thing. I use Vallejo cleaner, but, I don't think it gets through the system enough. I've broken down my AB tons since I started going between different brands of paint.
______________________________________________________________________________
On the Bench: Nothing on the go ATM
    May 2013
Posted by hogfanfs on Monday, May 18, 2015 8:33 PM
Steve, Rob,
Would a AGM-109 Tomahawk Cruise missile be a consideration for this GB? I found a 1/48 scale resin model, and thought it would be cool.
I missed a couple GB dates, so I'm tentative to commit to another.  Although this Tomahawk and the V2 should be quick simple builds.
Waynec, I'm at a loss for words at the size of the model. I could not imagine what the original would look like in real life!
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    July 2014
Posted by modelcrazy on Monday, May 18, 2015 11:32 PM
hogfanfs
Yep, awesome idea man. I like that out of the box thinking. I didn't even know they made a kit of a Tomahawk.
I'll out you down.
Steve
Steve
    May 2013
Posted by hogfanfs on Tuesday, May 19, 2015 6:35 AM
Steve,
Here is the box art of the Tomahawk:
And thanks for adding me.
 Bruce
    July 2014
Posted by modelcrazy on Tuesday, May 19, 2015 7:51 AM
I got your box art updated Bruce, thanks.
Steve
Steve
    April 2010
Posted by Theuns on Tuesday, May 19, 2015 8:11 AM
I think I might have come up with an idea for this GB. I am concidering to see if my spares box hold the bits to make  M388 Davy Crocket gun, if that fits the criteria  :-)
Theuns
    July 2014
Posted by modelcrazy on Tuesday, May 19, 2015 9:22 AM
Theuns
Yes.
Yet another great out-of-the-box idea (for a build, stupid idea for a weapon). I can change your TBA to the Davy Crockett if you want.
Steve
Steve
    April 2010
Posted by Theuns on Tuesday, May 19, 2015 10:31 AM
Ok, let's go for it, I found a bomb that looks like it might work nwith some sugery...
T
    July 2014
Posted by modelcrazy on Tuesday, May 19, 2015 11:34 AM
I got you updated Mr T.
Steve
    January 2014
Posted by Rob S. on Tuesday, May 19, 2015 3:22 PM
Geez Theuns...I had to look that M-388 up!! What a weapon...OMG, did this thing actually ever enter service??? LOL...imagine being 'that' crew!! Cool to mock one up, what scale would you do it in?
    April 2010
Posted by Theuns on Tuesday, May 19, 2015 11:18 PM
I saw a tv show on it yesterday and that gave me the idea. I have no idea what the scale would be, will have to work it back from the 1/72 bomb I can modify....maybe between 1/35 and 1/48 ....
The stand for the recoil less gun will have to be made from pieces of sprue. strangely there seem to have been a few different designs. I don;t know why they even had a sight on this thing, it was so badly in-acurate and the range was only about a mile, you could just aswell point it in the general direction and shoot it out the hip!
Maybe after I get the scale I will see if I can get the same size Willys Jeep, they were also mounted on that, it will atleast be less bland that way :-)
Theuns
    July 2014
Posted by modelcrazy on Tuesday, May 19, 2015 11:27 PM
Hey T,
That makes me wonder. Could you get the Jeep with the recoilless rifle from MPC and just that?
Steve
    April 2010
Posted by Theuns on Wednesday, May 20, 2015 1:17 AM
Maybe, I have not even started looking for a Jeep yet.....first need to get the budget for models up again. As for the Davy, I have made the bomb ans started working on the gun, I will call it 1/35.
(EDIT) I found a 1/35 M-151A2 Ford Mutt on the web , since it was in service between the 60's abd 80's and the M-388 was withdrawn in 1971, it stands to reason it might have been mounted on there...
Theuns
    April 2010
Posted by Theuns on Wednesday, May 20, 2015 2:04 AM
Check this out....goes to show how deep in doodoo you had to be to use this m388!
40.media.tumblr.com/.../tumblr_nkavpzCq8A1r94kvzo1_500.jpg
Theuns
    January 2014
Posted by Rob S. on Wednesday, May 20, 2015 4:33 AM
Stick out tongue
    April 2010
Posted by Theuns on Wednesday, May 20, 2015 5:23 AM
Here is the basic components, the low yield 0,1 Kilo ton warhead and the recoil less rifle tube.
Theuns
    April 2006
Posted by waynec on Wednesday, May 20, 2015 1:22 PM
Theuns my mortar platoon sergeant in '77 was in a Davy Crockett unit.
UPDATE
ammo and i have a 4th box.the rounds are split between smooth (for normal barrels)  and ribbed (for deep rifled barrels). i have a set out so i can use it for a mold to cast more if needed. i can use the smooth and put the ribbed on a pallet under a tarp.the rounds are painted Vallejo metallic black which i will tone down a bit with some pastels.  there were large and small powder charge bags (all are the same here). i will wash them to highlight the detail. the brass is the end piece and the minimum charge. the gray canisters i think can hold  the powder bags which would make sense. a max range on the ammo cart would be the projectile, 2 large and 1 small powder bag and the brass end piece.
like the couplers, now you know more about K-5 ammo than you will ever need.
Posted by Gamera on Wednesday, May 20, 2015 1:31 PM
Theuns: Now that's going to be something cool and different!
Wayne: Yow, those shells look about the size of the ones I've seen on the battleships USS North Carolina and Alabama!
    July 2014
Posted by modelcrazy on Wednesday, May 20, 2015 2:26 PM
That's some mighty big ammo Wayne. Can't wait to see how you present them.
Steve
    January 2014
Posted by Rob S. on Wednesday, May 20, 2015 7:07 PM
Cool Nuke Theuns...
Wayne...nice array of ammo for sure!!
Posted by Gamera on Thursday, May 21, 2015 8:01 AM
Gotta get some photos up for you guys since I am making decent progress on the Soviet supergun now. Nice kit, it's easy to build it up in a series of sub-assemblies (aka the gun itself, the cradle, the tracks), I just hope they all fit together when done!
    January 2013
Posted by jibber on Thursday, May 28, 2015 7:35 AM
    July 2014
Posted by modelcrazy on Thursday, May 28, 2015 7:51 AM
Terry,
That is going to be epic! I can't wait to see your masterpiece.
Steve
Posted by Gamera on Thursday, May 28, 2015 8:08 AM
Yes epic is the word for it! Looks great so far Terry, and I hope you feel better.
