Ok, one thing I have not found a lot of confusion and dissertation on is the color of the P-26's at Pearl the day it was attacked. In fact there is a veritable vacuum of info out there. I only found the one shot in the P-26 in action book.
Here are some kinda early sneak peaks at progress on the P-26. The aldclad is done, actually I found the perfect primer for it. On the top was Krylon gloss black, on the bottom is MM Gloss black covered with future. On the top I had trouble with "Spotting" some areas appeared to cover well, while others you could see the black through it and it took a few passes to cover it up. Underneath???? swipe swipe swipe and it was done!!! it went on beautiful! Also I learned the Badger 175 I have worked 100% better for it than both the 155 and Iwata HP-CR. I'll have to get a bottom shot in a little while so you can see, I forgot.
The cowl is still flat, I will gloss it before I stick it on permanently (it is just stck on there for now) I need to clean some overspray off and do some light sanding on a seam first.
Without further ado:
Next is the dreaded task of putting the fiddly bits on and then the bracing. (which is going to be a whole new game for me!)
---edit--- inserted the wrong code for the first image
