Battle of Britain GB 2006 - 1 May to 31 Oct 06
Posted by superbear on Tuesday, October 24, 2006 11:57 AM
Karl  Very nice work on both buildsThumbs Up [tup]  I realy like the work you've done on the Do.  Is your He-111 the Hasa P version?  if so how's the fit of the various assembly's, fuselage ,wings, engine.  I'm curious as I have the 111-P and I'm considering tackeling it next year after I've finished with my lancaster if it's not overly demanding.  Your thoughts would be appreciated.
Cheers
Bear
Marc
    November 2003
Posted by bobbaily on Tuesday, October 24, 2006 6:21 PM
Karl-very nice work on all counts.
Bob
Posted by rjkplasticmod on Tuesday, October 24, 2006 6:33 PM
Good progress Karl.  Looking forward to the finished build.
Regards,  Rick
    April 2005
Posted by wing_nut on Tuesday, October 24, 2006 7:33 PM
My my my Karl has been a busy little beaver.Wink [;)]
All look good Karl. Stop typing and start gluing.
Marc
Posted by espins1 on Wednesday, October 25, 2006 11:01 AM
Have I mentioned how much I hate masking lately?  Shock [:O] Dead [xx(]Laugh [(-D]
I got the Spitfire all masked, including the canopy, so I could spray the green camo pattern last night.  Man, talk about tedious.  I also accidentally cracked the rear piece of the canopy.  Oh well, it's all glued on and hopefully won't get damaged further when I remove the tape.  Would a bit of future in the crack help at all?
Anyway, I was all ready for the reward of being able to spray the finaly camo color only to find out that I'm missing one of the colors I need to mix together to make the green!  I have XF62 in my stash, but not XF58.  Oh well, I'll make a run to the hobby store at lunch and spray the green tonight.
Scott Espin - IPMS Reno High Rollers  Geeked My Reviews
Posted by rjkplasticmod on Wednesday, October 25, 2006 7:30 PM
Sorry to hear of your woes Scott.  Future wont do much to repair a cracked canopy.  Best to replace it.
Regards,  Rick
    September 2004
Posted by razordws on Thursday, October 26, 2006 9:12 AM
Hi guys,  I was working on my Fiat Br 20 last night preping some of the parts to get it ready for painting and I had to paint some parts with the MM enamel Italian Sand.  The color was a very pinkish biege and not at all what I expected.  Has anyone else used this color and have any comments?   I thought it would be a lot more yellow.
Dave
Posted by espins1 on Thursday, October 26, 2006 12:09 PM
I might be in luck with my canopy as it's a totaly straight "snap" and I think if I can carefully get the tape off and it stays intact on the plane a little future might help hide the crack.  I won't know though until after I remove the canopy mask.
I sprayed the green on the Spitfire last night, turned out great!  After getting a nice thin coat of green on it I lightened the paint just a hair and sprayed a little randomness to very subtly give variations in the color.  I'm going to spray a coat of Future on it tonight, decals go on tomorrow.  Big Smile [:D]
Posted by superbear on Thursday, October 26, 2006 2:48 PM
Sounds good Scott how about some picsBig Smile [:D]  I hope the canopy works out.
Cheers
Bear
Marc
Posted by espins1 on Thursday, October 26, 2006 3:23 PM
Cheers
Bear
You bet!  I'll be taking the tape off when I get home from work and will snap a couple photos before I apply the Future.  Smile [:)]
Posted by espins1 on Thursday, October 26, 2006 10:30 PM
Here's a pic of the camo right after I took all the tape off.
And here is the underside right after I sprayed the future.
Both of these are not in the best lighting conditions and well, I'm just too lazy right now to correct that.  Shock [:O] Laugh [(-D]
I have tomorrow off, which should give me plenty of time to do the decals, assuming the Future is nice and cured by then.
Posted by espins1 on Thursday, October 26, 2006 10:31 PM
Posted by superbear on Friday, October 27, 2006 9:55 AM
Scott  Looks Great the camo came out very niceThumbs Up [tup]  Did the canopy survive?  or will you have to go an alternate.   Looking forward to seeing the finished build.
Cheers
Bear
Marc
Posted by espins1 on Friday, October 27, 2006 11:04 AM
I'm happy with the way the masking job worked out, but I'm not too fond of the colors.  I think the Tamiya ratios for the colors are off.  Oh well, some heavy weathering will help solve that a bit.  Wink [;)]
I won't know for sure about the canopy until everythings is finished.  I'll be taking the tape off the canopy as the last thing I do.  If it's toast, I'll need to see about getting a replacement, but I think it's on there solid enough for now that I'll be able to finish it for the purposes of this GB, know what I mean?
    July 2003
Posted by KJ200 on Friday, October 27, 2006 2:01 PM
Guys, thanks for the kind words.
Scott, nice job on the Spitfire camo.
Bear, the Hasa 111P is a very nice, though not without it's foibles. The engines are multi piece assemblies and take a bit of care to ensure that every thing is aligned properly. Same goes for the engine to wing joint, which was fine underneath, but too deep on the top of the wing. Like I say, spend plenty of time on the dry fit and you'll be fine. That and the fuselage windows don't fit too well, being undersize for the appertures. Everything else is up to Hasa's usual standards though.
Progress Update
Tried posting this the other day, but haven't been able to get on the forum for some reason.
Decals are on, as are many of the smaller details.
I'll give it a coat of Future tomorrow, then a panel wash, before it receives a matt coat on Sunday, and some weathering.
Still waiting on the new vac form canopy to turn up, hence the lack of a lid.
Karl
    November 2003
Posted by bobbaily on Friday, October 27, 2006 2:35 PM
Scott-nice job on the camo.  Hopefully the canopy will be ok.
Karl-nice clean build.  Good to see a 109 without mottle.
Bob
Posted by espins1 on Friday, October 27, 2006 3:25 PM
Edit:  I figured it out.
Nice work Karl!  Looks great!
Posted by rjkplasticmod on Friday, October 27, 2006 8:33 PM
Scott & Karl,  Nice work guys.
Regards,  Rick
Posted by espins1 on Sunday, October 29, 2006 12:58 AM
Decals are on, just doing some decal softening with the roundels on the upper wing surfaces to get them to hunker down on a bit of raised surface detail.  I'll have some pics in the morning.
    July 2003
Posted by KJ200 on Sunday, October 29, 2006 10:55 AM
Thanks Guys
Matt coated the Emil this afternoon. I'm not going overboard with the weathering on this build, just a little exhaust and oil staining, which I'll add once the matt coat has had a few days to harden fully.
The Dornier is getting close to completion, but it'll probably be a few weeks yet.
Karl
Posted by espins1 on Sunday, October 29, 2006 9:43 PM
K guys, almost done.  Going to do the final glosscoat momentarily, oil wash and some weathering tomorrow, final flat coat Tuesday.
    April 2005
Posted by wing_nut on Monday, October 30, 2006 12:10 AM
Lookin' good Scott
Marc
    November 2003
Posted by bobbaily on Monday, October 30, 2006 9:57 AM
Ditto.  btw-I appear to have lost my 'smiley faces'.  Not a good day.  Oh bother.
Bob
Posted by espins1 on Monday, October 30, 2006 11:17 PM
Oil wash is finished, landing gear are on, propeller and spinner are ready to attach.
All that remains is a flat coat and the exhaust streaks.  Big Smile [:D]
Here are a couple more photos for those that are interested.
    September 2004
Posted by razordws on Tuesday, October 31, 2006 12:52 AM
Scott, looking good Thumbs Up [tup]  you should have no problem finshing it up in time.
Well I guess it's official.  The Italians are a no show.   I have not had much time or energy to work on it latley and I'm not even close.  Maybe it will be done in time for the BOB '07! Smile [:)]  Thanks Darson for another great GB and hope to see this back again next year.
 PS: Where did the smileys go?
Dave
    April 2005
Posted by wing_nut on Tuesday, October 31, 2006 7:16 AM
Looks good Scott.
Karl... Sorry man... don't want you to think I was snubbing you(hey, it was 1AM)... The 109 looks  great and I have to agree with Bob... I like the spliunter high on the spine and no mottle...looks great.
Marc
Posted by superbear on Tuesday, October 31, 2006 8:20 AM
Scott GREAT work on the spit it looks nice
Karl  Your 109 looks Great,  Thanks for the info on the He-111  it sounds like the same problem I had attaching the engines to the wing on the Hasa Lancaster that I'm still working on.
Looking forward to the final pics guys.
Cheers
Bear
Marc
Posted by espins1 on Tuesday, October 31, 2006 9:17 PM
Almost finished.  Weathering is done.  I'm going to be spraying the flatcoat momentarily.  I have two small clear pieces to attach, which I'll do after the flat coat is dry.  Oh, and the last thing will be to peal the mask off the canopy.
    November 2003
Posted by ghettochild on Tuesday, October 31, 2006 10:24 PM
Looking good everyone! Sorry I haven't had alot of time to build or post with a new baby in the house. But I have been working every chance I get. Maybe a couple more weeks to go!
-Josh
Posted by osher on Wednesday, November 1, 2006 7:38 AM
Another year, another BoB, and once again I didn't make it in time!  Sorry guys, but maybe next year?
