Greetings:
I have Cavalier King Charles Spaniels, easier for you to google than for me to explain. But pretty much lazy lap dogs, once they grow up!
The wing I was referring to is located on the very back of the rear wheel flip-ups. It went all the way across the rear cowl area and was right in front of the rear wings. I have to search my memory, but I think BAR was the first team to use this and most teams followed suit fairly quickly. For 2004, it is black and is also part of the rear cowling. BAR had, from front to back, red, tan and black on the rear cowl. The red and tan are decals, more on that later, with the black being painted. The trick will be to glue in the wing without creating a huge nasty seam line.
The side pod flip-ups you were referring to are also some nasty little monsters. Thank heaven they are white, but should be real fun polishing out the paint. So far the rear suspension looks 1000% better than the McLaren I finished. We won't go into that one. I'm just having small coronaries overthe red decals. If they are typical S27, should be no issue. Just a few nights of VERY delicate decalling. If not, well then... The only major screw up on the kit is the exhaust ports. The BAR had round pipes coming out a round hole on the cowl. S27 molded the exhaust ports as if they were the headers themselves. Oh well, insert some tubing and it will look fine.
Back to the grind. BTW, anyone else out there going to IPMS Nats in LA?
