Way to squeeze in some work raider 83! Figured you would be too sore to figit with the parts but glad to hear your making progress.
Nam I've been feeling guilty bout shirk me duties so I am following the Xo's example and burning some midnight oil! Trying to catch up.
Got the fuselage together and primed. Painful clean up as you say a strange mold. Large thick injector pin marks right on some details. . Side windows didn't fit. ( Made my own again) Adding quite a bit of scratch stuff. More than I had planned on but once started hard to stop.
Cleaning up the floats and added the center bracing wires out of real fine electronic wires. Trapped them in beween. Almost ready to paint. Odd there is no marks to show where they go on the lower wing? Have to wing it so to speak and add the 4 addition bracing wires to each float. ACK!
In betwwen drying times I noticed the tail had molded on detail that didn't cut it so I cut them out. The hinge and contol wire holes. Adding some home made conrol wires and PE hinges. EEKS! ( so much for a quick build like I said it would be)
Looked at som photo's of the real engines and wasn't satisied with the resin copies. I painte the plastic extras in the kit and was hard pressed to fins a detail diff. So I took the resin engines and looking at the photo added data plates and wires to match them up to the photo.
Starting to come together. Hopefully the pace will quicken once I finish the other engine. Trying to do that as paint/ glue is drying. The Ventura parts are supposed to finally arrive tommorrow so I should be able to get back into that as well!
Nam keep on with that SBD Dauntless! Skipper will find those Japs! He's part Cherokee Indian after all! ( from the Midway Movie!) My kids still scream Enemy dive bombers!!
