P-47 "Jug" Group Build
gzt
    May 2007
Posted by gzt on Thursday, August 30, 2007 6:41 PM
I found more on DBolt
 This is from "Zemke's Wolfpack"  William N. Hess published by Motorbooks International ISBN 0-87938-622-3 pg 138
This book is a great source of all kind of information on 56th FG from its beggining throught the WWII. Detailed description of combat actions as well as pictures and aircraft data.
Flying is a thrill #2 known to mankind. Landing is #1.
http://www.rwd-6.org
Posted by Anonymous on Monday, September 3, 2007 8:14 PM
GZT,
 Thanks for the pic of the cockpit area! I have looked at the pics of that plane and often wished there was a clearer pic of the canopy.
Kent
gzt
    May 2007
Posted by gzt on Monday, September 3, 2007 10:26 PM
I will keep my eyes on this case.
I did some painting tonight. Experimenting with  "black automotive paint" on Lanowski P-47M.
I am not sure if I got the effect I need.
    August 2005
Posted by fjs3 on Tuesday, September 4, 2007 10:56 AM
I want to take part in your group build for October.  I have the Trumpy kit in 1:32 and would like to give in a whirl.  I'll document everything as I go and send pics regularly.  Thanks.  Right now the kit is washed and drying before assembly.
Regards.
Freddie from LI
"I'm gonna build all these models one kit at a time!
gzt
    May 2007
Posted by gzt on Tuesday, September 4, 2007 11:26 AM
Welcome Freddie !!
Sign - Welcome [#welcome]
Nice Tbolt ! Post a lot of pictures here Big Smile [:D] so we can enjoy viewing nice JUGs
    August 2007
Posted by semibold on Tuesday, September 4, 2007 1:42 PM
i want use a metalizer base coat, what would be the correct kind? MM Aluminum?
gzt
    May 2007
Posted by gzt on Tuesday, September 4, 2007 4:35 PM
I used MM Aluminum Metalizer (non-buffing) for airbrush, but it is my first time Big Smile [:D], few more days and I will know if it was OK or not Big Smile [:D]
    August 2005
Posted by fjs3 on Tuesday, September 4, 2007 6:31 PM
Be careful with the MM Metalizer.  It should be OK as an undercoat but do not mask over it.  I would use the Non buffing aluminium and then put a coat of the SEALER they have over it.  That should protect it somewhat.  After you put on your topcoats, to make little scratches. you can use the tip of a #11 knife to GENTLY, and I maean gently 'chip' and 'scratch' away paint.  Again, even with the outer paint on the metalizer, be careful of masking as the tape may STILL pull off paint on you.  I would use drafting tape because it's ;ess sticky than regular masking tape OR take the piece of masking tape you and using and put it into your pants and pull it off a couple of times.  This will take some of the dtrong stickum off the tape and make it less likely to pull off you paint.  I hope that helps you out on this.  Good luck.
Regards,
Freddie
Posted by jeaton01 on Tuesday, September 4, 2007 6:44 PM
In my experience, which does not include the newest form of Alclad II, the SNJ aluminum is the toughest metalizer type paint.  It can usually be masked with Tamiya tape without problems.
John
gzt
    May 2007
Posted by gzt on Wednesday, September 5, 2007 9:02 AM
I was a bit unpationed and pilled off masking tape to see what kind of damage I will get by using MM Aluminum Metalizer (non buffing).
Here it is: P-47M painted with black automotive paint (it was though to match - when finish I will make sure the color is exact on the picture - correct White Balance) for now it is what it is- a quick shot with my Rebel.
and other side:
I checked some details and I do not see any damage on the paint. THe only thing I did - wait about three days for the aluminum to cure before I mask it.
I do not think it is so bad, is it ?
Posted by Anonymous on Thursday, September 6, 2007 8:28 PM
Aw, what the heck. I'm already down for the 1/48 "Doublebolt", so add the 1/72 Hasegawa "Bubbletop" P-47 that I've already gotten about 80% completed. I'll post pics of that one this weekend.
Kent
Posted by jeaton01 on Thursday, September 6, 2007 9:32 PM
Looks like a very fine paint job, Greg.  The masked lines look very good and the black is a nice even finish.  It's going to look good when it's done.
John
gzt
    May 2007
Posted by gzt on Thursday, September 6, 2007 10:37 PM
Kent: nice choice ! I added this build to the list !
John: thanks. It took me some time to matvh the paint color. I read about this particular case of color and it was realy though work - mainly because I never did such thing Smile [:)], my wife was a judge ! She sees colors much better than me Big Smile [:D] I can see just six maybe sever colors and the rest .... whatever Big Smile [:D]
Anyway, this color supposed to be black automotive (faded). Based on some stories I read, it supposed to look almost like black or a very dark blue, depends on the light angle. I think I got this effect - it may not be visible on the pictures above but the final I will take  with a correct white ballance and I hope it will be much better.
Now I plan to let it seat for few days and put some fading colors on spme panels on both upper and lower side.
gzt
    May 2007
Posted by gzt on Sunday, September 9, 2007 7:20 PM
Gentlemen:
I created a slide show of P-47 details picture slide show here:
http://gzt.myjalbum.net/P-47N/
 let me know any comments and ...
enjoy
 ps. I am not sure if this is a "D" or "N" - I thought it was "N" but the stenciling on the fuselage states otherwise... a mystery will be resolved on Oct 14th, another open cockpit day - I plan to take more picts of other planes there - Hellcat and Corsair
CORRECTION: after a short deliberation we came to the conclusion that this aircraft is a "D" - not "N" (~99% sure Big Smile [:D])
    July 2003
Posted by Circuitrider on Sunday, September 9, 2007 9:45 PM
Good stuff, Greg!  One of these days, I'm gonna work up enough guts to drill some holes in a perfectly good kit and slap on some wire/solder to replecate some of the pipe/hose/wire that your pics show so well!
gzt
    May 2007
Posted by gzt on Sunday, September 9, 2007 9:54 PM
I knew those will be helpful Big Smile [:D] LOL - in fact I messed up mine "M" but I do not plan to correct it, too painfull
If you want to see more from this museum, here is an additional link:
http://gzt.myjalbum.net/NEAirMuseum/
enjoy
on Oct 14 I plan to take much more details and cockpits of Hellcat and Corsair
gzt
    May 2007
Posted by gzt on Tuesday, September 25, 2007 8:28 AM
Just few more days for an "official" start !
We invite all of you who plan to build a P-47
    January 2007
Posted by Gigatron on Tuesday, September 25, 2007 9:00 AM
Is it bad if I got a little antsy and started early?  I didn't want to start one of the kits and then be halfway through when this started.  I'm not organized enough to do more than one build at a time Laugh [(-D]
-Fred
gzt
    May 2007
Posted by gzt on Tuesday, September 25, 2007 3:42 PM
Fred: it is very bad if you start early ... and NOT place any pictures here Big Smile [:D]
We need more WIP picts here ! This is the only (besides having fun) requirement
    November 2006
Posted by dupes on Wednesday, September 26, 2007 9:44 AM
Oh, I'm so in on this one. When I got back into modeling about a year ago it was all armor...but I've been slowly building up some aircraft kits in the stash - and those P-47's are calling out to me! Like everyone else I've got a bunch of other projects going on, but I should be able to start some time in October. It'll be 1/48, either a Hasegawa D razorback, or Academy D bubbletop.
I'm officially fired up. Smile,Wink, & Grin [swg]
gzt
    May 2007
Posted by gzt on Wednesday, September 26, 2007 5:45 PM
WELCOME ! Big Smile [:D]
You are in ! Officially starts next Week but ... some of us already build "Jugs" here
    January 2007
Posted by Gigatron on Wednesday, September 26, 2007 8:20 PM
Well, if you insist.  Keep in mind that these WIP pics are very, very poor and not up to my usual standard.  The completed pics will be much better
Here she is in primer, landing gears have yet to be assembled.  But you can see the resin gun and ammo bays
Here it is with a base coat of Alclad Aluminium and the white base for invasion stripes
Here, the white stripes have been masked off and the black stripes are painted on
Here a pic of the engine and cowling.  The engine is an odd mix of OOB and resin AM.  It took a lot of modding to get the two to mingle
And here she is as she stands today.  The stripes are completed, but the alclad needs a good buffing before I'll be happy with it.
Enjoy!
-Fred
gzt
    May 2007
Posted by gzt on Wednesday, September 26, 2007 9:06 PM
Fred: this  is an awsome build!
Thanks for sharing !
    January 2007
Posted by Gigatron on Thursday, September 27, 2007 7:40 AM
Thanks, Greg.
You'll notice how the alclad has the gritty look to it.  I'm hoping that once I get the buffing pads from micromark, I'll be able to smooth it out and get a nice, metal look to it.
If I ever do another BMF, I may try that acrylic stuff from falcon.
-Fred
    April 2005
Posted by wing_nut on Thursday, September 27, 2007 7:55 AM
Fred... Did you prime the model before spraying the Alclad?  That looks like the plastic got crazed but the Alclad.  It is lacquer based and pretty hot.  If that is the case I hate to be the bearer of bad news but you may not be able to buff that outSad [:(]
Marc
    January 2007
Posted by Gigatron on Thursday, September 27, 2007 9:16 AM
Yup, she was primed, as you can see in the first pic.  Also, if you take a look at the cowling, I didn't encounter the same problem.
I think what it may be is overspray that dried before it landed, giving it that gritty appearance.  Hopefully, with a little work, I can get a decent finish out of her yet.
-Fred
gzt
    May 2007
Posted by gzt on Thursday, September 27, 2007 9:34 AM
not too good news Angry [:(!]. Is it possible that this problem was caused wih too low pressure or position of the AB beeing too far from the subject ??
I got TALON acrylic paint and tried it on my scrap wing
I used Aluminum and Dar Aluminum on the front panels. The paint is OK but I have a real hard time to use acrylics. I was not able to get smooth layer, and you can see some overcoat in many places. This wing was originally painted dark see blue (enamels) and than with acrylic talon paint.
One more problem I saw - one of the jars - containing GUNMETAL paint was a bit ... blown. I opened it and released a lot of pressure. I thought first it was just packeging problem but after a day I saw the same bottle blown again - and again released some pressure. It make me think that there is some reaction going on - maybe contamination with some bacteria - something I never experienced with enamels.
    November 2006
Posted by dupes on Thursday, September 27, 2007 10:25 AM
Hmmm...was perusing my jugs last night, as well as some aftermarket decals I picked up, trying to match them to the kits I have...which leads me to my question, which is:
What's the difference between a P-47D, D-25, and D-30?
Any info (or a link) highly appreciated.
    January 2007
Posted by Gigatron on Thursday, September 27, 2007 10:59 AM
That's a great question as I've always wondered myself.  I keep finding those referenced, but never any info on the difference.
I think my hase is a D, the verlinden kit was for a D-25 and the AM decals were for a D-30.  So far, everything seems to fit A-OK, so I'm really confused as to what the differences are.
-Fred
Posted by jeaton01 on Thursday, September 27, 2007 11:55 AM
The block numbers on the P-47D tell a lot about the airplane.  Most US WW II aircraft got a new letter when any substantial change was made, such as P-51B and P-51D with the change from framed to bubble canopy, but with the P-47 they just changed the block number.  The main change that is externally significant (other than propeller types) was with the P-47D-25RE and P-47D-26RA, which was the change to the bubble canopy.  The P-47D block numbers went all the way up to 40.  The RE airplanes were built in Farmingdale, the RA airplanes were built in Evansville, Indiana.  Curtiss built the P-47G which was only used stateside.
John
