Alright, finally calling it quits. NMF is not my arena of choice but I finally completed one I'm mostly happy with. This is Hasegawa's 1/48. Built mostly OOB, I added detail to the main gear, and added a resin gunsight. Oh, and PE belts.
Paint is Alclad, Tamiya acryls, MM enamels. Weather is MIG oils and pigments. Flat is Polyscale.
Heck, OOB is out the window. I used Pyn-up decals from Cutting Edge.
Somehow I managed to muck up the nose art decal on the left side. After I had it in register I noticed that the image had some spots flaked off of it. Never knew it happened until later. So we wont look at that one to closely. I'm not sure if the plane was supposed to have nose art on both sides or not but I applied it to both sides anyway. The CE instruction with the cals made no comment about it.
I also cut the tail wheel strut away and made one from brass wire. Learning experiance, the raw brass rod could not be bent tight enough and kept breaking. A few seconds under the torch and the rod was like putty in my hands.
The plane is supposed to have covers on the wheels that are painted red but I had some Ultracast wheels in the parts box and could not resist using them. I guess that pretty well kills the OOB comment. I was not aware until now how much AM I used on this build. It was fun and I have two more to build, both with Pyn-Up decals. I was looking forward to this one being complete, not so much to be done with it but to see the final product.
Thanks for looking, comments welcome.
