ok, this is the dragon f2-g smart kit.this photo of the rear plate w/o mufflers in place ready for paint.the assembly is straight forward with no fit problems i noticed.watch your part call-outs as there are lots of un-used parts,depending on the period or version.
here shows the drive sprocket test fitted to the output shaft.nicely detailed final drive housing and armoured housing guards.the drive sprocket is four pieces but assembles nicely.
the bogey truck assemblies have a gigantic sprue attachment points that will make you say
#@%$!!.but after a little clean-up they come around.the upper hull is dry fit only.be aware of the proper direction of the round covers at the mountings as they fit only one way but can be mixed up side to side.
this view of the front is focused more on the firewall at the back of the fighting compartment.it is the kit part but modified to ressemble the firewall from th tankworkshop interior set.the white being added styrene details
this is just another angle of the same subject.
a photo of the partially assembled main gun.not pictured is the drilled out machinegun opening to facilitate adding an mg34 rather than just the kit provided stubby.
and finally a shot of a couple my reference materials.
again as with all of my recent photos,they may be a bit blurry,tried re-sizing,camera settings.a little lighting but that perfect photo eludes me.anyone who may have a suggestion feel free.the camera is a samsung 6.0 megapixel with asr,model s630
