Well,
I'm finally gotten underway with the Pampanito. So far, i've dry fitted her hull and bow planes and attached the template for where her limber holes are going to be. Man, I have a lot of work ahead of me.
First thing I will need to do is cover the holes for the side vent plates then lengthen the plates by adding sheet styrene, lengthen the side hinge plates by adding more sheet styrene all around. Second drill out new limber holes down the both sides of the deck.
Then I'll need to scratch build a larger set of bow planes. I'll need to cover the bow planes holes too and drill out a different set of holes there. Then cover the anchor well on the starboard and drill out new anchor well on the port side. Fill in and sand out the propeller guard mounts.
And so on and so forth. I haven't gotten to the deck guns or the conning tower yet. I'll keep posting my progress. Sorry about the picture, I just snapped this around 1:30 in the morning here in SF and I have go to work in the morning.
Thanks,
Albert
