Hi Frank and all,
More WIP, I've had a good day today. The Tamiya F-8 is moving along smartly. Here's the powerpack, unpainted, but for the engine:
All components are painted, below. The spinner cone and base, plus the accessory pack of the engine, were sprayed XF-18, Satin Black, and drybrushed in silver enamel. The cowling was sprayed FX-1 flat black, the prop blades XF-27 Schwartzgrun. The Tamiya version is not quite the same as the Model Master enamel, it dries lighter and is dead flat rather than with the low sheen of the original RLMs. I brushed the blades over with two coats of Microscale satin to give them a lustre, which also darkened the finish slightly. The self-levelling characteristic of this stuff is truly remarkable -- no brush strokes! The connections at the base of the blades were brushed into Humbrol aluminium, and the castelations highlighted with Promodeller wash.
Powerpack assembled, no glue or polycap yet:
Engline assembled, prop secured, mating surface cleaned of paint:
Prop assembled, plus cowlings painted and mating surfaces adzed clean:
Engine mounted:
And cowlings fitted:
Tomorrow should see the cowl ring, gunsight, payload racks and canopy hardware in place, and a lick of filler in a few spots. Then it'll be time to put her aside until the canopy masks arrive. That'll give me more time to decide which scheme I'll go with.
Cheers, Mike/TB379
