Progress -- I get the feeling I need travelling music when I post...
The Tamiya F-8 is finally masked and into the paintshop. I think I was putting off masking the wheelwells all this time... When I was a teenager I used to say "filling and sanding is the cross modellers bear," but I think I've changed my mind. I think it's masking! That said, some kit will probably turn round and bite me on fit in the near future...
Okay, 12 areas masked with tape, tissue and rubber solution, here she is:
![](http://i301.photobucket.com/albums/nn48/MikeTheModeller/Tamiya%20FW%20190%20A-8/DSCF7290a.jpg)
![](http://i301.photobucket.com/albums/nn48/MikeTheModeller/Tamiya%20FW%20190%20A-8/DSCF7291a.jpg)
I moved on promptly to painting. The markings will be Green Double Chevron of SG2, March '45, so it really is among "the last of the last," and the 74/75/76 scheme is accented with SG2's yellow rudder and cowl band. I'm doing this whole job in acrylics so I mixed the RLM 04. To begin with, Tamiya XF-3 Yellow to XF-7 Red (9: 1), though 5% would probably have been enough to warm the shade sufficiently. Then this mix was lightened with XF-2 at 1:1, though it could probably have gone lighter still, XF-3 is a surprisingly powerful tinting shade. 25% X-22 Clear Gloss was then added to the overall mix to bring up the lustre, as seen in the MM enamel equivalents.
Thinned 50%, I laid it on with my Paasche VL (which could have done with a tip clean, there are a few specks and spots here to deal with), like so:
![](http://i301.photobucket.com/albums/nn48/MikeTheModeller/Tamiya%20FW%20190%20A-8/DSCF7292a.jpg)
![](http://i301.photobucket.com/albums/nn48/MikeTheModeller/Tamiya%20FW%20190%20A-8/DSCF7293a.jpg)
The nose and tail bands are supplied as decals in the kit but if I was mixing the rudder shade I figured it was far better to paint the bands then struggle with decals, which are not guaranteed to match the colour of the rudder anyway. I mixed more paint than needed and ended up laying it on in several coats (also on the rudder of the Academy A-8 I started for this build), and will let the paint dry overnight before doing another round of masking.
The main camo I'll soft-mask. The division between the 76 flanks and the 74/75 upper surfaces is a straight line in the plans, and I'm not sure this is correct, after about 1940 and the time of hard-masking, the straight line divisions were replaced with wavy lines freehanded with the spraygun IIRC. Anyone have any thoughts on this???
Cheers, guys, fabulous work all round and I hope I can get at least this bird into the hangar on time!
Mike/TB379
