Fw 190 Butcher Bird 2013 (extended to June 2014) Group Build
    April 2013
Posted by SchattenSpartan on Friday, July 26, 2013 2:16 PM
If you decide on buying one, let me know by sending me a PM. I'll make a tutorial on how to clean/disassemble it for you!
    October 2008
Posted by Rigidrider on Friday, July 26, 2013 3:12 PM
Hey Greg... Like Joe had said to get a fine mottle I set the pressure I usually use (12-20psi) to about 30-35 psi, and at times set the travel stop(needle) to where you can just barely see paint when trigger is depressed,on the towel I keep in hand, Now most of the time(depending on the paint being used) I will either thin my acrylics with straight rubbing alcohol, or lacquer thinner. Usually I leave the travel stop so I can determine the ammount of spray, and when mottleing work slowly (I mean with purpouse) and excersise pantience. Some patterns require you to be up close (appx 1/4 in) and you must keep moving! Too slow and you will have a splotchy mess. Some mottle needs to be faint and some bolder.
My first AB was a Badger 350 I think, little black handle and adjustable cone on needle...3 Diff sizes, and I still have it, and use it on occasion, but now have fallen in love with the gravity fed double actions, so easy to maintain and use! I bought one of the Master Pros from TCP Global, and wouldnt trade it for anything. Any way... Practice Practice Practice!!! Take care!
Doug.
When Life Hands You A Bucket Of Lemons...
Make Lemonade!
Then Sell It Back At $2 Bucks A Glass...
    October 2008
Posted by Rigidrider on Friday, July 26, 2013 3:21 PM
Oh, Joe... That is going to be one Bad Azz 190! Just beautiful!!!
Make Lemonade!
    May 2013
Posted by Greg on Friday, July 26, 2013 3:54 PM
Doug, thanks for chiming in. I am very glad I asked now. Ultra-thinning, relatively high pressure and very low paint flow isn't something i would have considered. Now I need to work on the practice and patience part of it. Smile
Clemens, thanks for the tute offer my friend.  I looked at the exploded view, looks like a nice, straight-forward airbrush. That said, should I get one I would be most interested to learn how you clean yours, indeed.
    August 2009
Posted by JOE RIX on Friday, July 26, 2013 4:06 PM
A simply marvelous job Joe. It really is a reflection of the monumental effort you have put into it.  And as far as the little issue with the lower nose, well I don't notice a thing.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    March 2012
Posted by mustang1989 on Friday, July 26, 2013 8:46 PM
Rigidrider: Thanks Doug. It's coming together one little bit at a time. I don't have just a whole lot left. Canopy and aerial, cowl guns and access cover, prop and spinner and then the little stuff. Antennas and the like. Another month or so and we'll be home. I plan on finishing a Dauntless dive bomber with my son and then its off to the D-9 that I'll be opening up more than this one.
Joe Rix:Thank you as well. You probably know more about my struggle with this thing than anyone. Can't wait to see some more pictures out of you pal.
 Forum | Modelers Social Club Forum (proboards.com)
    August 2009
Posted by JOE RIX on Saturday, July 27, 2013 12:24 AM
You got it Joe. I have repaired the chips that pulled off with the tape and have applied the gloss coat. thusly the decaling can commence.
This here is what I used for the gloss coat. It's acrylic and seems to work quite well given that I tested it on my stunt model and slathered it with Mig wash and then with turpenoid with no ill effects. Unfortunately, I had to go to the True Value Hardware store aka "The Evil Empire" to get this. It's just that I work at Ace Hardware.
In the meantime I had a nice thing arrive in the mail. Got this from the Squadron sale:
    April 2013
Posted by FlyItLikeYouStoleIt on Saturday, July 27, 2013 2:53 AM
Joe and Joe, stellar work, men.
mustangJoe: That's gonna be one mean looking Butcher!
JOE RIX: I can't wait to see how that camo looks when you add your finishing touches. It'll be striking.
I absolutely must get building again. I took a lil break from it after my 190 and I'm starting to get into trouble. i pulled a TIE Fighter off the shelf and gave it some needed weathering. Took the edge off the craving but nothing like the real fix one gets from building.
Bill.
On the bench:  Lindberg 1/32 scale 1934 Ford Coupe and a few rescue projects.
In queue:  Tamiya 1/35 Quad Tractor or a scratch build project.
    April 2013
Posted by SchattenSpartan on Saturday, July 27, 2013 10:16 AM
Greg: It is really easy to disassemble and clean the Evolution, but I got some hints at my LHS how to make things even easier!
Joe (Rix): Your 190 is looking really good! I found some decals for that camo-scheme in 1/48, so I think I have to get me an F-8 as well (Eduard 1/48 Weekend)
    March 2012
Posted by mustang1989 on Saturday, July 27, 2013 10:19 AM
FlyItLikeYouStoleIt
Thanks Bill. You should grab another 190 and build. I may end up extending this build for a couple of months so I can work in my D-9. There is some great participation here and good people here so its making my decision to extend it a bit even more tempting.
Posted by Bish on Saturday, July 27, 2013 10:55 AM
I know I haven't posted in a while, but I have been checking in every so often. Still some stunning work going on in here, great to see the GB is going strong.
Mustang, that's looking really nice. For a difficult build, you are defiantly getting a gem out of it.
JOE, love that paint scheme. I saw that on the decal sheet, I might have to try that one day.
    April 2013
Posted by SchattenSpartan on Saturday, July 27, 2013 10:58 AM
I think I have enough kits to participate in this GB, even if you extend it for a whole year:
  • Eduard Fw 190A-8/R2 (on the bench)
  • Eduard Fw 190A-8
  • Eduard Fw 190D-9 Weekend
  • Eduard Fw 190D-9
  • Eduard Fw 190D-11
  • Hasegawa Fw 190A-5 w/ staff car
  • Tamiya Fw 190A-3
  • Dragon Ta 152C-0
  • Zoukei Mura Ta 152H (still have to buy that one)
    March 2012
Posted by mustang1989 on Saturday, July 27, 2013 11:33 AM
SchattenSpartan
  • Eduard Fw 190A-8
  • Eduard Fw 190D-9
  • Eduard Fw 190D-11
  • Tamiya Fw 190A-3
  • Dragon Ta 152C-0
Bring it on bro. My bets on the Tamiya though. Nice and easy build. The ZM. Not a chance if you want to pull a nice build off on that one. Those are sweet kits though. One of these days I'll talk the wife into one. I think ZM is trying to come up with an A version sometime in the future. They are supposedly gathering information off of an A these days.
    April 2013
Posted by SchattenSpartan on Saturday, July 27, 2013 12:36 PM
A radial version would be really awesome! Especially with all that interior detail ZM is providing with their kits! (like a big Eduard 190!)
I'm going to build all Eduard kits simultaneously as soon as I finish those Thunderbolts.
    March 2012
Posted by mustang1989 on Saturday, July 27, 2013 12:38 PM
SchattenSpartan
One things for sure. You'll definitely have the hang of Eduard 190's!
    August 2009
Posted by JOE RIX on Saturday, July 27, 2013 11:27 PM
Thank You Very Much Gentlemen.
Hey Bish, How have you been doing? It's great to hear from you. Saw your Me 262 over in the 1/72 GB. Excellent work. Given that Joe is going to extend this GB (hint, hint) I may build Hasegawa's 1/72 D-9 and also cross it over to the 1/72 GB.
    April 2013
Posted by FlyItLikeYouStoleIt on Sunday, July 28, 2013 2:00 AM
SchattenSpartan
See, I KNEW he lived in a mansion.
Bill.
    August 2009
Posted by JOE RIX on Sunday, July 28, 2013 5:51 AM
FlyItLikeYouStoleIt
SchattenSpartan
And I knew that he lives in a time zone that has 48 hrs per day.
    October 2008
Posted by Rigidrider on Sunday, July 28, 2013 6:44 AM
Morning All!
Gotta get caught up here... Joe R, Man what a busy scheme that is! Ialso saw the decal sheet with that color pattern and its going to look great when you finish! Silly putty is the way to go!
Clemens... You really are bit with the Eduardtosis! I'll be starting mine this week some time I hope.
Bill, you just cant help it now..., The glue fumes are inhaled and soak into your skin and thats it... Its in you now and it drives the urge to build! Finishing one eases the pang but before the last touch up paint and fiddly part is applied your already thinking of the next project!(ha)
Guys.. I just got back from the LHS and OMG!!! The owner (He knows my weakness for WW2 aircraft and Luftwaffe in perticular) walked me to the store room and opened a box (I hate him so much) and pulled out a 1/32 HE111!!!  Revell of Germany, various versions can be built, including a torpedo carrier!
This kit is going to sell for about $80bucks! Fuse approx 18in, wing span approx 24 in... I think he knew I was hooked by the drooling maybe? Also (not yet arrived) he has several 1/32 B-17s comming! approx 36in wingspan! They will sell for about $260.00. Guess I better start saving my sheckles! Also better plan on buildind a bigger dog house! (lol)
Take care guys!
Doug
Make Lemonade!
    April 2013
Posted by SchattenSpartan on Sunday, July 28, 2013 8:08 AM
Bill: Nope, no mansion. Just a medium sized flat in an old building in vienna (4th floor). I can't afford a mansion with all those models on by wishlist... Stick out tongue
Joe: My timezone has 24 hours, but I just go to bed really late (3-4 AM). Building time is from 10 PM to 2 AM.
So here is a question to you: What are you guys even talking about?
Doug: Yep, I need help... Do you know any doctor with experience regarding Eduartosis? Wink
    October 2008
Posted by Rigidrider on Sunday, July 28, 2013 8:51 AM
Sorry Clemens... No cure... you just have to keep building to keep the cravings to a minimum. Sorry, (ha)
Make Lemonade!
    August 2009
Posted by JOE RIX on Sunday, July 28, 2013 9:43 AM
Doug, Not sure if you have checked out the latest Squadron sale but, they have the Revell 1/32 HE-111P on sale for $41.29. Sale ends tonight.
    March 2012
Posted by mustang1989 on Sunday, July 28, 2013 2:00 PM
JOE RIX
Thats a friggin STEAL!! If I built 32nd scale stuff all the time I'd be on that like a rat on a cheetoe!!
    August 2009
Posted by JOE RIX on Sunday, July 28, 2013 2:39 PM
mustang1989
JOE RIX
Hey Joe,Also seems to be a few items there that are right up your 1/32 Luftwaffe Alley.
    October 2008
Posted by Rigidrider on Sunday, July 28, 2013 3:12 PM
Joe... You would tell me that ...(LOL) No I hadnt noticed but I will here shortly! Thanks...
Make Lemonade!
    October 2008
Posted by Rigidrider on Sunday, July 28, 2013 3:25 PM
Hey JoeR... I must be looking at something diff then you, The He111P is listed at 105.00 and the He111N is 76.00? The P is the one I saw in the LHS with the "N" at about the same as squadron. Still darn good prices!
Make Lemonade!
    August 2009
Posted by JOE RIX on Sunday, July 28, 2013 3:42 PM
Hmm, Doug here is the one I'm lookin' at
www.squadron.com/.../rm5628.htm
    October 2008
Posted by Rigidrider on Sunday, July 28, 2013 5:19 PM
Thanks Joe... Dont know why I didnt see that one, I punched in He111 1/32 and saw the other two . But again, Thanks!!
Make Lemonade!
    October 2008
Posted by Rigidrider on Sunday, July 28, 2013 5:30 PM
OK... I see the differance now... The one you saw was Revell America and the one I was looking at was Revell Germany... The only thing I noted differant was the Revell America said in the description "Ex Revell AG Molds" whatever that means. Well, were going to find out pretty quick! (ha) Thanks again Joe!
Doug
Make Lemonade!
    August 2009
Posted by JOE RIX on Sunday, July 28, 2013 5:34 PM
My pleasure me compadre. I so wish I had the space to display 1/32 kits as I sure would be into buiding them. I still eye the Revell 1/32 Ju88 and that He111 would be choice to build. Alas, I am certainly fine with 1/72 & 1/48 though.
