Been slowly progressing on the Stuka with the priming and painting. After painting the yallow markings this were masked off. I had originally planned on adding and msaking the markings before painting, but have decided to add them after. So once everything was masked, it got a coat of Alclad grey primer. I then had to go back and touch up some seams with filler and sanding.
The underside then got its blue coat. I am useing MRP for the first time and was expecting to need to apply at least 3 coats, but this went on really nice and just one coat gave a great finish, though i did give it a light second one. I am really pleased with this and am giving a lot of thought to switching to this as my go to paint at least for German aircraft and maybe even armour, thats after over 20 years of sticking to Xtracolour.
The only 2 downsides with the MRP is the cost, even allowing for the extra paint in the bottle it cost more than what i use now. But given how much i waste with tins going off, i thnik that will balance out. And the only negative is having to apply a gloss coat if useing decals, but given the fast drying time, adding a couple of coats of gloss won''t be to big an issue.
So i am going to do the top side and see how that goes. I still have plenty of Xtracolour, so i might keep the MRP for larger models for now. But i will see how it goes and as my Xtracolour runs out, i might well be replacing it. MRP deffinetly gets a from me at the moment.
The cannon ha also been put together along with some wiring and have been apinted.
Not sure how long i need to leave this before masking, so will play safe and wait until tomorrow.
And with the time i had while leaving the Stuka to dry, i have made a start on the 190. Main focus has been on the Aires resin pit and undercarrage. The pit has been apinted and weathered and just need to add some final details.
And the wheel wells were fitted and painte, just need to add some washes and dry brushing.
Thats all for now. Thanks for looking.
