I am finished my Academy 1/72 F4F-4 Wildcat.
Had a blast building this little guy. Had no real issues with fit except I missed sanding a seam down right in front of the cockpit.
Completed it in about 8 days, 5 actual sittings. Pretty fast for me.
I used Tamiya acrylics on the exterior. Painted it using the tamiya paint scheme from the 1/48 f4f-4 kit. Mixed the paints according to tamiya instructions.
Anyways, here are some pics. In progress.
A bit of a fit issue with the wings to fuselage. Had to fill with .10mm plastic sheet. Also the gear door fit like garbage.
I ended up painting over the view windows on the bottom of the fuselage. Forgot to mask them off. Luckily the acrylic just scraped off with no problem once it was complete.
The completed bird.
Shaded panel lines, highlighted afterwards with a pencil. Weathered with smoke from tamiya's weathering kit.
The antennae were made from stretched sprue. I drilled a hole in the fuselage to accomodate the antennae.
Again, I had a blast and thanks for letting me join. I can't claim to have the greatest skills, but I think it turned out pretty well :)
Mick
