Ok dokey I got the pics and the understanding now Guy Thanks a bunch you were a big help there and I salute your greek god modeling mind if not your flapping in the breeze appearance although I think I have seen several greek statues like that!
I'm with Dave there Dirk! Wow Alliteration! Anyways Dragon has not the greatest batting record with aircraft! The Revell and PE I think is the best deal and the most enjoyment or frustration for the $! That's my 2 cents!
Ok Day 3 of elbow grease and I think I am about to the painting stage.
Defining elbow grease with raised details is a dif approach for me. To explain lets look!
![](http://i952.photobucket.com/albums/ae5/EngineerAaron/DSC02783.jpg)
The larger holes were filled with tresters clear parts cement a white glue. When dried it held sucessive coats of CA and accelerator, bit by bit seam by endless seam I used this process.
Sanded it smooth as I could wet sanding with an emery board and using white primer to really show the flaws!
After it all dried I used a good coat of Mr Surfacer 1000 to build up and cover the things I just couldn't smooth over without destroying the raised details. Let that dry. Then a quick wet sanding with fine sand paper. enough to kinda polish but smooth the brush lines. OOO shiney! Its the Future!
![](http://i952.photobucket.com/albums/ae5/EngineerAaron/DSC02791.jpg)
Then this is the main diff with raised details. To smooth out any remaining sand marks and brush strokes a double heavy coat of Future was applied. Pretty heavy. Any runs were left to dry and smoothed over with a cotton Q-tip and windex when dried.
![](http://i952.photobucket.com/albums/ae5/EngineerAaron/DSC02794.jpg)
Then all dry a final complete coating of White primer over the future and final inspection. It's all white now as I snapped these while waiting the drying times, The Future self levels filling small impections but the raised details still come through like a champ! Recessed details would be filled up and smoothed out by this process!
What little there is is easy enough to bring back out with a simple scribe when it is completely dried. But it does take time to smooth out the unsmoothable!
![](http://i952.photobucket.com/albums/ae5/EngineerAaron/DSC02795.jpg)
![](http://i952.photobucket.com/albums/ae5/EngineerAaron/DSC02796.jpg)
So now all white and happy with the seams or lack of them now! When dry I am ready to paint er up! Uh what colors were they? Duh?
