Hi All,
Looks like things are coming along great! I just made a post about how to improve the Tamiya ETC 501 rack for my long buried Tamiya Fw 190 A8/R2 project. If you have any interest in seeing what I did, take a look here. As mentioned, I’m not super happy with the result, and may take another crack at it. After all, the only cost is time and effort…
It looks like there are a lot of Tamiya & Eduard kits being built; I can’t remember if anyone is doing both at the same time, but if you are here’s a neat tip. I’m not the first to notice this, one of the accuracy problems with the Tamiya kit is the canopy, if displayed open is that the front edge is too wide.
The real aircraft starts wide at the engine and tapers continuously to the tail, so that means an open canopy will be narrower then one that is closed - thus the hinged section on the top of the canopy. Here’s the A–5 I saw recently:
If this matters to you, it’s very easy to swap in the canopy from the Eduard kit. The Tamiya kit parts will fit pretty nicely, with only a small bit of filing in the armored head rest. The best part is that Eduard gives you two canopies in their kits; “flat” and “blown” versions. So if you’re doing both at the same time, or have one of the Eduard kits in your stash, you’re golden. Next time I get a chance, I’ll post some pics of the Tamiya & Eduard parts together.
Keep up the good work!
Best regards,
