Hi Guys,
Even though I’m not participating in this GB, I wanted to share my experiences with the Eduard 190 kits. I recently finished the A–8 model, and the fuselage / bulkhead / cockpit / wing fit was disastrous. In fact, I had shelved the model for a while out of disgust and depression about that. However, I’ve since started a D–9 (with a WIP post about it elsewhere), and had a lot better success in this area. Although everything forward of ammunition holders on the firewall is different, everything rearwards is the same.
There were two main errors I made:
A. Believing that the bulkhead parts are supposed to be 90° in relation to each other
B. Believing that the forward edges of the cockpit floor were good relative alignment points
So, on the first part, in the 190 D–9 manual, I found this:
Why ever it wasn’t included in the A–8 manual, I’ll never know. But that made a huge different. OK, 3° isn’t a large amount, but given the engineering of this kit, that made a huge difference in my case.
Secondly, as was pointed out on the ARC site some time ago by a fellow whose name I can’t recall, it’s important to focus on the fuselage sides and firewall alignment and let the cockpit float. Only cement it in place later.
In my case, these two things made a massive difference.
I hope this helps just a little bit.
Best regards,
